Hpt
Old Jul 11, 2007 | 05:16 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Question Hpt
How do you change your tune from a 4L60E to a 80e with HPT
thanks
Old Jul 11, 2007 | 06:48 PM
KySilverado's Avatar
Find a stock tune from same year as your truck that came with a 4l80e. Transfer the rest of your settings from your current tune into it and use "write entire" when you flash your PCM.
Old Jul 11, 2007 | 07:39 PM
Low_LSX's Avatar
Do you have one??
Old Jul 11, 2007 | 08:16 PM
Wheatley's Avatar
Truck Sponsor
About to have one your way
Old Jul 11, 2007 | 09:10 PM
Low_LSX's Avatar
Thanks for all the help
I'm going to try it after work and hope my truck will run tonight
Old Jul 13, 2007 | 06:36 PM
gmforlife's Avatar
Yep pretty much it, you go into the tune repository on HPT, or get someone on here to get you a stock file, looks like you found someone to help you out with that, and basically copy over all of your engine settings to the new 80 file, don't just copy the tranny tables on the 80 file over to your current 60 file, won't work. Just wanted to clarify that. So you basically are using the 80 file, and copying over your motor and DTC's and what not.
Old Jul 17, 2007 | 12:26 AM
Low_LSX's Avatar
Got it i'll try it tommorrow
Thanks alot
A.J.
Old Jul 17, 2007 | 09:11 PM
99RCSB's Avatar
I am getting ready to start my swap,but have a question about the tune. I have started my 2 bar OS tune,but its registered to my truck. If i take a 4l80e file and transfer all my tables to it i'm going to loose my 2 bar right? Will my 2 bar stay with my vin if i do a vin change on the 4l80e file? I'm trying to find he most economical way of doing it. Your helps greatly appreciated.
Old Jul 18, 2007 | 01:27 AM
gmforlife's Avatar
haven't gone 2bar so really couldn't help you on it, but i would think that it stays with your vin. Basically to do a swap you have to get an OS that matches your existing so that you can change your vin to match. That's what i know, might not be of any help.
Old Jul 18, 2007 | 01:33 AM
Low_LSX's Avatar
I still have my old 2 bar but can't use it with the 4L80e
I had to use a new License with the segment change
mhorn0817
Jan 26, 2022 08:48 AM
MikeD.
Sep 18, 2015 09:55 AM
GM1697
Sep 9, 2015 10:31 PM
GM1697
Sep 9, 2015 01:52 PM
muncie21
Sep 7, 2015 09:55 PM
