HP Tuner tranny shifting problems....
Old Dec 15, 2007 | 09:01 PM
YenkoST's Avatar
Default HP Tuner tranny shifting problems....
The 1-2 shift at 100% throttle is not upshifting...however, it will upshift at 90% or if I let out of it a little bit....I put the stock settings back in from the rpm/mph shifting points. I lowered the shift time...I put it at .200 and wasn't a problem before I changed the rpm/mph shift points. 2-3 shift is fine.....just the 1-2 is messed up for some reason. Any help would be appreciated.
Old Dec 15, 2007 | 09:33 PM
nonnieselman's Avatar
If i were you i would lower the whole MPH table by say 10mph... and set your RPMs for when you want it to shift...
Or vice versa....
Both the MPH and RPM have to be met before it will shift
Old Dec 15, 2007 | 09:54 PM
YenkoST's Avatar
Or vice versa....
Now..that makes sense....I lowered it down to 36 mph in normal, performance, and hot.....and 5600 rpms. Now, 265/75R16 tires with a 3.73 gear...you think this would be fine? Or should I lower the mpg to 33-34 or a little but more.
trever1t's Avatar
2nd fastest 5.3 ECSB
Or vice versa....
If I may jon in,
Both have to be met? My rpm was set at 6400 rpm for the 2-3 and my speed was set at 84 mph - it was shifting at 83-84 but at a lower 5800 rpm.
Now my speed is set to 90 and 6400 rpms and it's shifting at 89 mph/6250. What's up with that?
Old Dec 15, 2007 | 10:06 PM
YenkoST's Avatar
Also..I heard the lowest time on shifting should be .200 is this correct?
Old Dec 15, 2007 | 10:09 PM
Thats what i did on mine anyway... lowered all the MPH talbes down 10 or so... and used just the RPMs for my shifts...
I wouldnt mess with any of the HOT settings...
Just keep playin with it to you get it where you want it...
I had my RPM set at 5900 but sometimes on the 1-2 it wouldnt shift until 6100-6200 if it was spinning cause it got there so fast.. so i lowered it to 5800 and its a lil better
on the 2-3 it shifts when its suppose to.. at 5800...
Old Dec 15, 2007 | 10:11 PM
Originally Posted by trever1t
If I may jon in,
Thats the impression i was under....
hum... that sounds odd.... maybe i need to go try a few things before i start opening my mouth..
Yea if you have a Stock transmission...
Look in to a servo set or atleast a Corvette servo..
Old Dec 15, 2007 | 10:13 PM
trever1t's Avatar
No, I think you are correct but maybe there's more to it? I have always heard that both must be met also.
Old Dec 15, 2007 | 10:24 PM
YenkoST's Avatar
Part of the problem to is as well...if feels like it wants to shift and then just sits there at like 5900 rpms and is slow to get into 2nd then just feels dead....Abuse mode is disabled and TM is still active, I still have
Old Dec 15, 2007 | 10:31 PM
YenkoST's Avatar
I added my stock tune and the retuned Modified tune.
