how would you know ecm is dead
Old Jul 25, 2015 | 04:46 PM
ou812sm's Avatar
Default how would you know ecm is dead
My truck is completely dead if the ecm is dead how would you now
Old Jul 25, 2015 | 11:51 PM
Suburbazine's Avatar
You would know the ECM is dead if it had a hole from a .44 Magnum in it.
No, seriously.
Old Jul 26, 2015 | 07:47 PM
marlboroman71818's Avatar
check battery voltage. check voltage to a power accessory like the cigarette lighter fuse. if you have power to these two then check power to and out of the fuse for the ecm. also check power to the ecm itself with the key on. plug in a scanner to the obd2 port.
Old Jul 27, 2015 | 04:30 AM
ou812sm's Avatar
No power to obc2 port to scan for codes
Old Jul 27, 2015 | 08:15 AM
Check the cigarette lighter fuse under the hood
Old Jul 27, 2015 | 09:12 AM
ou812sm's Avatar
I've checked every fuse i haven't found a burnt one yet i check under the hood and in the dash board
Old Jul 27, 2015 | 09:38 AM
tgui's Avatar
My initials are ecm, am I dead?
Old Jul 27, 2015 | 10:50 AM
Do you have 12v to the cig lighter fuse?
Old Jul 27, 2015 | 12:21 PM
ou812sm's Avatar
No 12volts everything is dead
Old Jul 27, 2015 | 05:13 PM
Is your battery dead too? The cig lighter doesn't run from the ecm I believe, so you either have a dead battery, bad ground, broken positive wire or loose or bad connections at the battery or somewhere else
