How to run a larger DBW Throttlebody without an x-link
#51
#52
I have a 2003 that I'd like to be able to run the larger TB when I swap on the TBSS intake.
#53
#54
Has anyone with this swap tested their cruise control function? It is the last item I am trying to get functioning on my setup. My P59 will not even respond to manually disabling the lockout in the HPT scanner. I am starting to believe something in the communication between the early TAC module and the P59 is not allowing for the cruise control to function as I have verified all the wiring, Brake/TCC switch signals and the tailight resistance on the brake switch pin to the TAC is correct.
#55
I did a GM 90mm gold plate DBW TB with a NNBS intake, got the Michigan Motorsports crossover pig tail. I have a reduced power message. I did not change the TAC, is that necessary if the truck is 04? I ordered a adapter plate to try the old TB to see if reduced power clears. Anything else I should be looking at? The truck was tuned after cam, heads and fan convertion and ran fine.
Truck is 04 2500 Crewcab
#50 injectors
243 ported heads
stage 2 BTR cam
electric fan convertion
Thanks in advance!
#50 injectors
243 ported heads
stage 2 BTR cam
Thanks in advance!
#56
#57
#50 injectors
243 ported heads
stage 2 BTR cam
Thanks in advance!
#50 injectors
243 ported heads
stage 2 BTR cam
Thanks in advance!
The whole premise of this thread is swapping the tac module dude....
lycominghunter
17
Oct 26, 2017 05:41 AM
UnrthdxDream
Apr 23, 2015 07:39 PM
89LS1FOXER
Jul 8, 2012 08:23 PM
