How to - Logging boost in HPT Scanner 3.x
A better way would be to just subtract atmospheric pressure from your MAP sensor. I know for a fact the 99-07 gas trucks dont have a baro sensor (just a MAP), not sure about the diesels. If the baro value defaults to 14.6, which is sea level, it will only be accurate if you are at sea level. At 6000ft altitude ambient pressure is around 12psi.
The MAP sensors read absolute pressure anyway, so 10psi of boost will read 24.6psi on the gauge. If you know your ambient pressure, just subtract ambient pressure the MAP sensor.
03sierraslt
Jun 11, 2012 12:05 PM
