How to disable PE?
I just got HP MPVI 2.1.4 USB.When tuning the LTFT's and STFT's everyone says to disable PE by setting LTFT enable to false.In the version I have it is not under edit-engine-fuel control-Open&closed loop. Under LTFT Enable it has Min ECT-131*F and Max ECT-284*F.It does not show true or false.
Disabling ltft is one thing but disabling them and PE fueling can be bad if the tune is not perfect
DO NOT DO THIS UNLESS YOU HAVE A WIDEBAND 02 SENSOR
Originally Posted by 02sierraz71_5.3
There is an on/off feature for your LT's just disable them. If you are disabling your lt's and PE fueling you better make damn sure that your VE table is perfect, if not you run a great risk of running very lean up top. If your not sure about your VE being able to command the proper AFR WOT do not disable your pe fueling!!!!
1. edit-engine-fuel control-Open&closed loop
a. set long term fuel trim enable to false
i. this disables your long term fuel trims in the interests of time and simplicity{unquote}
Now how do you go about it a safe way?I do not want to blow any thing up.All I have done as of now is take out 80%TM and up my shift rpms,and upped my rev limiter.I know I am new and I DO NOT really understand at this point.I have been reading alot and I am getting a little grasp on it.Please help me understand what I need to do.
When you disable ltft's the pcm doesnt remember any fuel trimming and in SD runs completely off the VE table, this means that any STFT that you get are directly from the ve table and not effected by any trimming memory. This is helpful for tuning the VE.
Now if you disable pe fueling and your ve table is not commanding at least a 13:1 afr wot you can run into problems. This is why we want to be dead certain that your ve table is perfect before you drive around without any pe fueling and no trimming memory (LTFT). You should have an on-board wide band before you attempt disabling pe fueling. With no lt's and no pe fueling you are removing any safety measures or any room for error with fueling, I wouldnt do it unless you feel confident with your abilities.
Originally Posted by dewmanshu
I haven't read your tuning write up in a while, does it tell people to command 13:1 in the open loop table?
If that was the case, you couldn't tune your STFTs at all, as a NBO2 cannot tell what 13:1 is.
Originally Posted by dc_justin
No, it doesn't.
I understand, I was just to lazy to open his write to see he wrote it for NB tuning or hasn't changed it from such. I am in the middle of all this myself, but I have a Wideband
