Hey look another fan question
Old Feb 15, 2013 | 08:12 PM
2K Silvy's Avatar
Default Hey look another fan question
Before I go on I did search for this. I didn't find what I was after so here we are.
How much control do we have over the fans using the computer? I am looking for it from a cold start start a 0% on both fans and slowly go up as the engine temp does. As it goes up around 50% (or whatever the best noise:performance) then fan #2 kicks on slow and gets higher. It is way better than having 1 fan roaring at 100% all the time.
As you might have noticed I am going for the quietest as can be. So do we have control over percentages or is it a on/off kinda thing?
Old Feb 15, 2013 | 08:34 PM
oakley6575's Avatar
There is a Fan Desired % vs ECT. I've never tried turning the fans on at cold idle and ramping them up like you stated. I personally dont see a reason for it but that table is there on my 2003 file.
Old Feb 15, 2013 | 08:49 PM
2K Silvy's Avatar
Yea I guess that would be kind of stupid. Forget that part as it wouldn't really make sense and almost be a waste of time.
Thanks for the quick answer and that is what I wanted. So at normal temp I can set them to be quiet then turn off when driving. Perfect.
Can anyone confirm this setting on the 2000 computers?
Old Feb 16, 2013 | 09:43 AM
Boober's Avatar
On my E38 the low limit is higher than my normal coolant temp with a 180deg T-stat. So I personally haven't been able to have auto fan activation other than switching on the A/C. There is a manual "test" for the fans in the VCM section of my HPTuners scanner. Any time i want to manually turn on my fans, i use it. I'm sure there is an equivalent in EFI.
lawhitediamante
Aug 12, 2015 12:14 PM
RONIN LSX
Aug 10, 2015 04:45 PM
bbowerman
Jul 26, 2015 10:57 PM
76k10chase
Jul 17, 2015 01:48 PM
bsn1989
Jul 16, 2015 08:20 AM
