Help!! wont stay running.
Old Sep 18, 2012 | 02:55 PM
N/ALS1's Avatar
Default Help!! wont stay running.
So finally got the lsxrt intake installed with 8.1 non-marine injectors and an aeromotive fpr. The problem is the truck will not stay running. it will try to crankover but nothing. Also the speedometer is now maxed out. What could be the problem? I know it needs to be retuned for injectrs and intake but shouldnt it run?
Old Sep 18, 2012 | 03:07 PM
06murder's Avatar
No ground...you must of forgot a ground on the motor
Old Sep 18, 2012 | 03:09 PM
N/ALS1's Avatar
I didnt tae any grounds off the motor.
Old Sep 18, 2012 | 03:11 PM
06murder's Avatar
Did you see if you getting fire?
Old Sep 18, 2012 | 03:12 PM
06murder's Avatar
There a cap on drivers side for fuel pressure checker did you push the valve to see if you getting fuel?
Old Sep 18, 2012 | 03:13 PM
SuperStepside's Avatar
So youre saying that it will crank but not fire up?
Old Sep 18, 2012 | 03:16 PM
N/ALS1's Avatar
yea it will crank but wont start. I gave it gas and it will run but I dont think that is god so I am not gonna do that. I have fast rails.
Old Sep 18, 2012 | 03:19 PM
Gave it gas how? Pressing the gas pedal or shooting carb/starter spray into the engine.
Old Sep 18, 2012 | 03:21 PM
N/ALS1's Avatar
pssing the gas pedal
Nice truck also SuperStepside
Old Sep 18, 2012 | 03:26 PM
AndysC3's Avatar
double chack if all the wires are connected.
