Help! Truck's slow :( Logs inside
Old 10-30-2011, 09:05 PM
iamkeniff's Avatar
I run 20s but run a bigger motor an i run 8.5s on a stock converter. Jamedee is on 17s but a 275/60/17 i think.
It looks like your truck doesnt leave as hard as it should but that could be of the 20s and street tires or the fact that you may be just easing out the hole.
Old 10-30-2011, 09:35 PM
AJII's Avatar
Originally Posted by Gadgetized
Are they also running 20's? They will slow you down a ton.
Yes, 20s. But in my searching, most the trucks I'm comparing to also run 20s.
Originally Posted by iamkeniff
You want me to email you a tune to compare to? I think i can get my old 6.2/60e tune with the 3200....
Also i can get you the tune you asked for if ya want.
Your 6.2 tune will be so different it won't help much But that other tune would be good I'll PM you my email
I'm definitely easing into it, but the 60s aren't horrible (but definitely not good!)
But perhaps with tires (and a working posi!!!!) I could actually nail it out of the hole. And see sub 2sec 60s
Old 10-30-2011, 09:40 PM
9 Second Club
Rhino79's Avatar
I use efi and cant see the logs, what wot timing are you running and what shift points? You should run 8.5-8.7 even on the 20's
Old 10-30-2011, 09:45 PM
AJII's Avatar
That's exactly what I was figuring...my truck's a dud
6500 and 28
Old 10-30-2011, 09:55 PM
NightmareTBSS's Avatar
After I found out it was a 6L I realized you should have been beating on my back bumper with the setup you have. What converter speed are you running again?
Old 10-30-2011, 09:58 PM
AJII's Avatar
Pour salt on the wound why don't ya
Circle D 3200 restalled TB. Comparable to yank TT3000
Old 10-30-2011, 10:12 PM
nonnieselman's Avatar
Have you tried adjusting your timing down low when you first go WOT?
Old 10-30-2011, 10:17 PM
Totally wasn't meaning it like that! I'm saying the potential is there (I know it).
I knew it sounded waaay better than last time I heard it. I think I only told ya 15 times..
Old 10-30-2011, 10:23 PM
AJII's Avatar
I added about 5 degrees all over with no KR from the first run to the last, and it made no difference in times.
It's like an old cammed 80s C-10..sounds beast, runs like poop
But it is crazy how much difference it sounds now than with the 5.3.
Old 10-30-2011, 10:30 PM
Laid Back
Beatdown Z's Avatar
Originally Posted by AJII
I wondered the same thing...I have stock intake
Is the entire intake stock, tube and all?
I had the IAT's that high a few weeks ago when I was at the track and my computer was pulling all kinds of timing. A good CAI combined with a moderate IAT timing table is better than a hot-air intake with a nearly zeroed out IAT timing table, imo.
I can't show you the tune for my truck, but I can let you take a look at a log I scanned at the track. Notice how the timing starts low when I go WOT and then ramps up to max timing.
File Type: hpl
Quick Reply: Help! Truck's slow :( Logs inside
