Help. No power windows or locks
Put the carb on this weekend and now I have no power windows or locks.
Quick run down of electronics I touched. Cut all wires from engine harness to fuse block under hood except for what is needed for the ac to still work.
Regrounded main ground from that harness
Rewired alternator with 470ohm resistor to switched 12v
That's it
EVERYTHING works EXCEPT the driver and passenger side power windows and locks and the passenger side power mirror. Driver side power mirror does work.
DDM fuse in the fuse block inside has power as does the PDM.
The only wire that has power on the DDM is the orange wire at the top of the module
Help
That's it
Help
I also tapped into a pink wire on a plug on the steering column that was switched 12v, a yellow wire for the starter on the same plug and another, I think it was a red wire, for a constant 12v for my msd ignition.
Any of those wires make a difference? Any or the wires I cut out of the engine harness make a difference?
I just don't see how anything I did would effect the power windows and locks
Most likely its on the interior fuse panel and what ever you cut under the hood is not affecting it unless there is an accesory power or body power that was cut or removed.
DDM and PDM was the only thing I can remember seeing on the interior fuse panel that had to do with the power stuff. It's just weird that everything works except this stuff
I'm looking for any and all info I can find to help me figure this out. I will rewire the switches if I can figure out what does what
