help is needed. cooling fan issue.
Old Nov 13, 2014 | 11:03 PM
WS64Mula's Avatar
Nelson performance..... Sent a PM
Old Nov 14, 2014 | 12:55 PM
WS64Mula's Avatar
Found the problem. One of the wires pulled out of the pigtails. Had enough to part of the system, but not enough for the other half. Pia!
Old Nov 17, 2014 | 11:55 AM
Nelson Performance's Avatar
FormerVendor
Well that sux, Just told the harness guy to give each harness a more thorough pull test on each wire. Glad you found it.
Old Feb 3, 2018 | 10:30 AM
Reckless's Avatar
Still moddin'
Dug this one back up. I have F-Body fans and I am using the Nelson harness. Both low speed fans operate when the engine is running, and then the high speed engages with the A/C clutch wire. Is there a way to make the fans come on with temperature from the ECU as programmed? The harness I have just has the single wire to the PCM.
CD82
Oct 23, 2015 07:32 AM
Lthompson
Oct 2, 2015 12:45 AM
carid
Oct 1, 2015 09:22 AM
Wrecker 426
Sep 30, 2015 09:39 PM
redbird555
Sep 30, 2015 09:28 AM
