Help me get this 4.8L running!
Old Sep 6, 2013 | 11:05 PM
  #31
smokeshow's Avatar
Mod with training wheels
I don't think my ve table even goes up by 25% at 320kpa. But yes, start with a value that you know is rich and lean it out from there.
Old Sep 23, 2013 | 06:05 PM
  #32
oakley6575's Avatar
Okay boys. I got the new map sensor in with FIC 850cc injectors and a vacuum block. When I fire it up, it will start for a quick second and then dies. When I scanned it, the MAP stays on 22 kpa. Am I just not getting signal from the map or do I have the MAP linear and offset off?
MAP is part number 12223861. Linear is 308.20 Kpa and offset is 1.11 Kpa
Old Sep 23, 2013 | 06:41 PM
  #33
smokeshow's Avatar
Check voltage output with key on. Should be in the 1.5v range.
Old Sep 23, 2013 | 06:49 PM
  #34
oakley6575's Avatar
I'm getting 5v
Old Sep 24, 2013 | 01:45 PM
  #35
oakley6575's Avatar
Okay as i figured, the cheap *** map I bought on ebay was a dud. Last night I ordered the MSD 2313 map from summit and got it installed just now. Fired up and I'm getting good MAP readings . My dynamic airflow is the same as calculated airmass now with the 3 bar OS. The fuel trims were between +30% and +50%. So I will get tuning on the VE.
Old Sep 24, 2013 | 02:09 PM
  #36
oakley6575's Avatar
Here is a log. Why would my bank 2 STFT be so much higher than bank 1? The truck has open headers right now so I don't know if that has something to do with it. Might be getting weird readings since the O2 sensor is in the collector..? I don't know
Another question. I'm getting a MAP linear of 308.19519 and an offset of 1.10 for part number 12223861. Do I adjust the offset until I see the correct barometric pressure for my location when the engine is off and key is on? Or do you guys just roll with the calculated offset?
File Type: hpl
File Type: hpt
Old Sep 24, 2013 | 04:59 PM
  #37
smokeshow's Avatar
Could be a bad O2. I have seen that before. Even if it switches it doesn't mean its accurate. For the MAP, just go with those values. The MAP sensor is absolute pressure; it isn't relative to location or elevation. If the linear and offset values are correct for that sensor, it will be accurate.
Old Sep 24, 2013 | 06:00 PM
  #38
oakley6575's Avatar
Golden, thanks Jake. Turbo kit should ship at the end of this week. Then the real tuning begins.
Old Nov 2, 2013 | 03:32 PM
  #39
oakley6575's Avatar
Okay the truck is up and running. Fuel at idle seems spot on. Haven't driven it yet because I need to set up a spark table. Can anyone help me out with this? I'm guessing I need to start out around 12-14 degrees in the higher cyl airmass parts of the spark table. Can someone upload a sample table for me so I can see where I should start lowering the spark?
File Type: hpt
Old Nov 3, 2013 | 08:18 PM
  #40
oakley6575's Avatar
Okay made a bunch of changes and I need help from you boosted guys. In the log, you can see in frame 697 that I am getting some mean knock because BE is really delayed. The truck is in boost for a few frames before it kicks down into BE. Is there a reason that it is so delayed? It happens again at frame 1602. Maybe I just set my BE enable to 95kpa or something? Thanks guys
File Type: hpl
stealthperf
34
Feb 14, 2016 11:35 AM
lycominghunter
Jul 29, 2015 04:24 PM
lxcoupe
Jul 27, 2015 08:19 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
Moto733
Jul 12, 2015 10:25 PM
