Help finding Throttle Control Actuator / Throttle control Computer
Old Mar 14, 2006 | 04:19 PM
Flyer's Avatar
That is off of a 99-02 truck/SUV with *traction control*. Traction control being the key there.
The electronic box with a cable attatched you are referring to is the cruise control box.
TO answer you're questions about the PCM, in 03, they changed up a little bit, so no, they are not the same. The 03-up PCM is the preferred one, but the 02 is the better of the 99-02 years.
Old Mar 14, 2006 | 05:30 PM
Wong's Avatar
http://www.hotrodlane.cc/PDFFILES/LS...stallation.pdf
Do the 03's not have traction control? Will they work with an 02 ECU? Do you know if it can be turned off with HPTuners? I'm using a 700r4.
Oobray
Jun 13, 2022 03:38 AM
thunder550
Oct 8, 2015 04:53 PM
grantpo
Jul 15, 2015 12:21 PM
davis28905
Jul 8, 2015 03:20 AM
