Help with EfiLive Spark tuning
Old Jul 15, 2009 | 09:45 PM
gao8302's Avatar
Default Help with EfiLive Spark tuning
I have looked and looked for a good write up on spark tuning with EfiLive. Everything says that it should be done on a dyno...which is fine. But i would like to get it close or within reason before jumping on the dyno. I have already tuned the truck pretty good fuel wise and the Ve table is almost spot on. Im running a COS3 and the mods in my sig. So if you guys can post up a good write up or give me a hand that would be great. Thanks alot.
Old Jul 15, 2009 | 09:52 PM
nonnieselman's Avatar
its more a trial and error kinda deal.
when your AFR starts to richen up, try to add a lil timing there.
Old Jul 15, 2009 | 09:58 PM
Atomic's Avatar
I have a gauge for that
Best power is around 30 degrees at WOT, but dont leave consistent spark knock in the tune.
Old Jul 15, 2009 | 10:11 PM
gao8302's Avatar
Ok so WOT spark timing is just hit and miss. What about part throttle? Is there anything i can log like DYNCYAIR_DMA to help me see where im at in the spark table like in VE tuning? Im new at spark tuning so ill take all the help i can get guys
Old Jul 15, 2009 | 10:16 PM
yep.. and go to your B page under dashboard... select your wot pass and go back to your tune and it will be selected where its reading from.
Old Jul 15, 2009 | 10:24 PM
gao8302's Avatar
So the DYNCLAIR_DMA.pid is used to tell me what spark timing im actually using at that given RPM, and if im using the High or Low Octane table? How do i use this to help me tune the timing? Sorry like i said im new at the spark thing
Old Jul 15, 2009 | 10:44 PM
gao8302's Avatar
Also when adding spark should i be adding it to the High octane table and just subtracting 2 or 3 degrees from the Low Octane table? Do i do anything with the Optimal Timing table. Thanks
Old Jul 16, 2009 | 04:29 PM
gao8302's Avatar
Can anyone answer my questions? Or add some more input for me on spark tuning?
Old Jul 16, 2009 | 07:28 PM
Atomic's Avatar
Cant help you there bud, I use hptuners.
Old Jul 16, 2009 | 08:40 PM
fastgmc98's Avatar
Add spark/timing to the High Octane table
To determine if your using the High or Low octane table log the PID GM.ASPARK
