Heads/cam ls3 tune check!
Old Dec 21, 2023 | 07:48 AM
robbieroflcopter's Avatar
Default Heads/cam ls3 tune check!
My current tune and a log with some idle and wot. I've got it to where I think it runs good. Wot afr is around 12.5 (didn't have my wideband attached). My only want at this point would be for it to fire faster on the start? Is there a trick to that? The stock lm7 fired quick. This one takes ~2 seconds of cranking. Once it fires it starts good. Or is that just how it is with a cam? What do you think of the tune in general? Glaring issues?
It's a blueprint ls376 530hp btw.
File Type: hpl
Old Dec 22, 2023 | 07:20 PM
smokinlmm's Avatar
My 408 was slow to start as well. It was my ground cable, sob has a sensor in it that was bad.
Old Jan 1, 2024 | 09:23 AM
MikeGyver's Avatar
Did you check the fuel pressure from a start? What is your fuel system? Aftermarket pressure regulators don't all maintain pressure when the pump is not running. I have an aftermarket regulator, and if I turn the key on for 2-3 seconds before I crank it, the engine fires immediately. If I don't, it will crank for 2-3 seconds before it fires.
Old Jan 1, 2024 | 12:02 PM
Default 255lph pump w in line regulator
It pressurizes when I turn the key on and then stops. It definitely leaks down after sitting for a while. Surprisingly it doesn't seem to matter though. Regardless if I go straight to cranking or wait for the pump to shut off it takes the same amount of time. I also pulled some timing to see if that would help it start faster. Went clear down to 10 degrees and it was slower each time. It likes alot of timing apparently.
Old Jan 1, 2024 | 01:09 PM
MikeGyver's Avatar
Originally Posted by robbieroflcopter
...if I go straight to cranking or wait for the pump to shut off it takes the same amount of time...
Lane_Hesser
May 16, 2017 07:38 PM
Markystang
Apr 1, 2016 04:44 PM
MaDChevy95
Dec 15, 2013 09:43 PM
CrunkGM99
Apr 25, 2006 09:25 PM
