Harness plugs
Old Oct 14, 2015 | 01:13 PM
Silver8ado's Avatar
Default Harness plugs
Just swapped a l96 and 6l90 from a 2012 into my 2007 silverado.
Everything plugged in except for these two wires:
http://imgur.com/fucQc3a
Theyre located on the drive side frame next to the transfer case.
Any idea what these wires control?
Any solution to get them to mate
Old Oct 15, 2015 | 08:05 AM
DrX's Avatar
DrX
Imgur: The most awesome images on the Internet
Recently purchased the motor, trans, transfer case, and wire harness from a 2012 silverado to go into my 2007 silverado. Everything has been swapped into the truck in place of the old 5.3. Everything bolted up and plugged in except for a wire or two to the transfer case.
My question is how can a plug-in on the harness not hook up to the transfer case it originally came with?
Also, what would it take to fix this and would it only take a new bcm and a tune to get everything including the 4wd to work?
The garage is completely lost so any help is appreciated!
Are you saying that these are part of the 2012 harness you bought? Was there a sub harness attached to the new transfer case?
Old Oct 15, 2015 | 09:13 AM
Silver8ado's Avatar
Kennif figured it out, they go to the fuel system. Just need to swap pig tails. The bigger problem is getting the 4wd to engage with the new transfer case, according to a tuner
matysik27
Oct 30, 2015 01:26 AM
Silveraydo
Oct 13, 2015 08:49 PM
Silver8ado
22
Oct 13, 2015 06:54 PM
FlowmasterMufflers
Oct 13, 2015 11:05 AM
Silver8ado
Oct 12, 2015 05:15 PM
