hard start after flashing tune
Old Jul 31, 2013 | 06:11 PM
sprayedenali's Avatar
Default hard start after flashing tune
how come after every time I flash a new tune my truck wont hardly start and will only run for a second or two then shuts off?? then all the sudden its like something flips a switch and it runs fine.........
Old Jul 31, 2013 | 07:35 PM
subeone's Avatar
ive had those problems several times.. no clue.
Old Jul 31, 2013 | 07:38 PM
03sierraslt's Avatar
I am betting you are speed density, if so then it is because it has to set the MAF code and learn the idle trims as I was told. Mine does the same, it has done this since I went 2bar in 06'
Old Jul 31, 2013 | 07:48 PM
Yup, I'm SD. I wonder if I completely disable whatever code you're talking about it'll fix that..? Like instead of just having it set to no mil report or whatever it's called?
Old Jul 31, 2013 | 08:27 PM
It has to set in order for it to go into Speed density mode.
Old Aug 1, 2013 | 09:23 AM
ooo... JK
Old Aug 1, 2013 | 09:27 AM
TXsilverado's Avatar
my 408 did that for a while. i have no clue what charlie did to fix it but it fired right up after every tune after he messed with it. i want to say it was in the base idle airflow table? i'm probably wrong.
Old Aug 1, 2013 | 09:28 AM
dirt track racer 81's Avatar
Mine does the same. A lot of vehicles actually do that and are still using the maf.
Old Aug 1, 2013 | 09:35 AM
my carb setup doesnt. carb>efi
Old Aug 1, 2013 | 09:48 AM
Depends on whether you got fuel in the bowls or not lol
