guys using torque pro
Old Apr 18, 2013 | 07:12 PM
RedRobinYum's Avatar
Default guys using torque pro
Ive done some search and didnt have the luck i was hoping. Ive had a random misfire code for a little while and I downloaded Torque Pro like quite a few folk told me so. And yes its showing the same code. Is there anyway to check and see which Cyl. or cyls that are misfiring to narrow it down and fix this?? thanks guys
Old Apr 18, 2013 | 07:41 PM
Nevermind that post guys. Sorry about that. talked with a buddy of mine and he said the p0300 code meant all cyl. were misfiring
Old Apr 22, 2013 | 12:22 AM
Suburbazine's Avatar
Your buddy overstated the problem. P0300 merely means that there is a misfire and the PCM can't track it down to a single cylinder. While having multiple cylinder misfires will indeed set P0300, it could also be one cylinder missing at random, internal engine noise, weak fuel pressure, etc. It could even be a faulty crank position sensor.
Old Apr 23, 2013 | 10:27 AM
Fastcount03's Avatar
It could also be an intake gasket leak(or other vacuum leak). 9 times out of 10 that is usually what it is when a customer brings me a vehicle with that code.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
