GMT900 steering wheel position sensor replacement?
Old Aug 25, 2014 | 07:41 PM
thunder550's Avatar
High on diesel fumes
Default GMT900 steering wheel position sensor replacement?
Anyone done one on a GMT900? Got a C0455 code on my wife's 2011 Yukon. Haven't looked at the sensor yet, wondering if there's an special alignment or anything tricky that needs to be done, or if it's as simple as pulling the old one and reinstalling the new one.
Old Aug 26, 2014 | 10:29 PM
Bit's Avatar
Bit
I believe you have to take the column out, or at least lower way down. The bolt for the sensor is on top of the colomn. After that you will need to have the steering wheel postions relearned.
Old Aug 27, 2014 | 06:33 PM
DrX's Avatar
DrX
The sensor is just held in place by a plastic clip and should slide off the column once the column is removed. New sensor is supposed to be pre-centred. I bought one for my 2010 Av after the Stabilitrak started doing crazy things and I found a code for the sensor. Sold the truck before I received the sensor though, and it has been fine since I unplugged the sensor and slid it down the column to read the part number off it, then plugged it back in. Just gave the sensor to the new owner. Apparently there were 2 different part numbers used in 2010 and they are not interchangeable.
Attached Thumbnails GMT900 steering wheel position sensor replacement?-steering-sensor2.gif   GMT900 steering wheel position sensor replacement?-steering-sensor1.gif
Old Aug 28, 2014 | 04:34 PM
thunder550's Avatar
Perfect, thanks for the info. I'll probably try and knock this out this weekend.
Old Aug 31, 2014 | 01:09 PM
thunder550's Avatar
Got it done this morning, thanks again.
Old Aug 31, 2014 | 03:13 PM
DrX's Avatar
DrX
Good to hear. Plug n play, codes gone?
Old Aug 31, 2014 | 05:18 PM
TIM Z's Avatar
11 sec. Truck Mod
Hmmm , didn't know they had a steering wheel sensor ,
I wish there was a way to completely get rid of the damn stabilitrak on these trucks .
Old Aug 31, 2014 | 07:24 PM
thunder550's Avatar
Plug and play yes. It's not popping up with Service Stabilitrak anymore, but I don't have a Tech 2 to clear or see the BCM (or ABS? can't remember) module codes. Had to visit a buddy at a dealer to find out the code.
I actually like the system, think it works really well. I gave it a workout in my LML when I was up in Colorado
Old Aug 31, 2014 | 07:37 PM
DrX's Avatar
DrX
Yeah, I had to use my OBDLink MX to find that a code was set.
Old Aug 31, 2014 | 07:46 PM
thunder550's Avatar
I'm assuming it will clear on it's own after a certain number of error-free ignition on events?
