getting a dtc with new setup
Old Sep 4, 2009 | 07:46 PM
VHslow's Avatar
Default getting a dtc with new setup
I just put a TBSS intake and TB with a X-link on my 6.0 and every time I give it full throttle it goes into reduced engine power and shows code
P2101. Is tunning required for this swap? anyone have any ideas?
Old Sep 4, 2009 | 07:49 PM
dlt76028's Avatar
I think it has to do with the TB. Which one did you use?
Old Sep 4, 2009 | 07:57 PM
VHslow's Avatar
The TBSS 90mm
Old Sep 4, 2009 | 08:21 PM
dlt76028's Avatar
hopefully someone else will come in and tell you exactly. It seems like it has to do with using a car TB over the truck.
Old Sep 4, 2009 | 09:17 PM
krambo's Avatar
Did you happen to cut the two looped pink wires on the X-link (provided it is version II). If so, they should be connected for use with the TBSS type TB.
Old Sep 4, 2009 | 10:40 PM
VHslow's Avatar
It is the version II, and the pink wires are untouched still in a loop.
Old Dec 13, 2009 | 04:43 PM
VHslow's Avatar
I'm still having the same issues with this P2101 code, Is the problem in the tune? or do I have a bad TB and or X link?
Old Jan 5, 2023 | 05:54 AM
07blackmax's Avatar
did you ever figure this issue out? I’m having similar issues but not at wide open throttle. My truck will randomly rev up and go into limp mode while idling.
Old Jan 5, 2023 | 07:41 AM
RDF1's Avatar
DuNnO
5 Year Member
VHSlow hasnt logged in since 2010...
Old Jan 5, 2023 | 08:03 AM
shakenfake's Avatar
Shlumpt
5 Year Member
14 year thread revival
