Gen IV knock sensors on Gen III?
Old Feb 7, 2013 | 01:24 PM
banker099's Avatar
Originally Posted by TXSZ66AVLANCHE
You can use stock 99-06 knock sensors, buy a new knock sensor harness and extend the wires. Easy easy easy
Originally Posted by AKlowriderZ71
I think this would be the better way to go about it. Plug & play. Aren't the Gen 4 knock sensors 2 wire? With different resistance values?
i went and got 2 new knock sensors and knock sensor harness at lunch...we'll see what happens later this evening
Old Feb 7, 2013 | 01:40 PM
TXSZ66AVLANCHE's Avatar
I did this mod to someone elses truck, he thought you needed to use an impact on the knock sensors and stripped out the threads on both.
Old Feb 7, 2013 | 06:53 PM
TIM Z's Avatar
11 sec. Truck Mod
In for results , hope it works for you , pulling the blower and tub kinda sucks for one guy , hard on the back lol
Old Feb 8, 2013 | 09:47 AM
banker099's Avatar
I put one right behind the PS Pump...did some scans with HPtuners, seems to be working fine.
idk where i can put the other one, the a/c is in the way on the other side.
Old Feb 8, 2013 | 10:29 AM
DrX's Avatar
DrX
Some screw them into the back of the heads.
I had to tweak the tune to get my LS1 sensors which are screwed into the sides of my LSX block to pick up anything.
Old Feb 10, 2013 | 10:29 PM
I'm converting my TA to the LS2 style flat response knock sensors that bolt to the side of the block. The shop in san antonio that does my tuning said no problem getting them to work with the 02 pcm.
I'm having to do this because I'm building a Iron LS2 for it using a LY6 6.0 block. I'm building the motor now so it may be a couple months before it's running and can first hand confirm what they say its doable. We'll see
Old Feb 11, 2013 | 12:53 PM
carbongmc's Avatar
I used a gen3 block in my gen4 build. We drilled and tapped the webbing on each side of the block. Pass side was above the starter if I remember correctly, but anywhere should be fine in that area.
Old Sep 24, 2014 | 09:43 PM
TURBHOE's Avatar
anybody get ls2 sensors to work on a gen 3 computer reliably? i'm in the middle of a l92 swap now and trying to decide which sensors to use on it.
lucas287
31
Jan 12, 2021 06:18 AM
5.3lSilverado
Sep 20, 2015 06:48 PM
elir_mn
Sep 19, 2015 11:43 AM
Pimpinpete
Sep 8, 2015 07:39 PM
chvy=power
Sep 8, 2015 11:06 AM
