Gauge Glitch in Tahoe
Old Nov 6, 2014 | 04:22 PM
InsaneDomestics's Avatar
Default Gauge Glitch in Tahoe
01 Tahoe gauges have a glitch, they sweep and reset everytime I hit the slightest bump.
Now theyre completely off, no rpm, speed is pegged out at 100+, no gas, no volts, water temp sits at 160 and climbs to 185 just to go back to 160, and oil pressure barely moves off 0.
There arent any lights for the P.R.N.D.3.2.1. either.
Any ideas on how to fix this?
Old Nov 6, 2014 | 04:24 PM
FFDP's Avatar
Get the cluster rebuilt.
Old Nov 6, 2014 | 04:30 PM
Where can I get that done?
Old Nov 6, 2014 | 04:37 PM
FFDP's Avatar
You could contact a local auto parts store and see if they send them out for rebuilds, some dealerships send out too.
I know where I live, a place in the cities rebuilds them for all the local shops and only charges around 150 for everything. Do some internet searching for your area and see if any place near you does this kind of work.
I would also remove the cluster and double check the wiring for any damage or see if the connector has any issues. But more than likely the cluster is faulty, extremely common on the 03+ trucks. But can happen on any of the GM truck clusters. Normally the oil pressure or volts and the speedo always max out or get stuck, even seen the speedo needle snap off because it went too far.
Old Nov 6, 2014 | 05:35 PM
Ive removed the cluster already, didnt really see any thing abnormal.
Old Nov 6, 2014 | 05:59 PM
Cluster rebuilds usually only involve the stepper motors for the gauges and seem to be an issue more so on 03-06 models. If your PRND321 isn't illuminating I'd be looking for a missing 12V or ground.
Old Nov 6, 2014 | 06:37 PM
Its wierd, when I start it and Im in Park, they illuminate and the RPM work as well as oil pressure and at times the volts...
When I put it in gear and start driving is when everything goes haywire.
Old Nov 6, 2014 | 08:06 PM
black04's Avatar
Check your battery terminals. I had the same thing in my 03 would randomly cut out and I couldnt figure out why. Then one day I noticed the terminals were corroded so i cleaned them and never had a problem after that.
Old Nov 6, 2014 | 09:25 PM
Iconic Motorsports
ground on the back of the head on ls CARS can do that when loose, check grounds.
dantheman1540
Feb 24, 2016 09:56 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
Infernohoe
48
Oct 2, 2015 10:25 PM
mitchellmade
Sep 27, 2015 08:27 PM
zblee
Sep 17, 2015 07:58 AM
