fuel trim difference
Old Jan 8, 2006 | 01:16 PM
chrisj6's Avatar
Default fuel trim difference
What is an acceptable difference between banks 1 and 2 for the fuel trims? My bank one is sitting at +1.6% and bank two is at 0. I thought this was a little much but wanted to know what yall think. I think I might have an exhuast leak but I cant find it anywhere, I've searched every inch of the trucks exhaust with it running.
Chris
Old Jan 8, 2006 | 11:24 PM
Crash Dummy's Avatar
Former Moderator :(
That's normal , 1.6 % is a very small amount. If it was 0 an + 10% then I would br looking for a vacuum leak or some related item
Old Jan 9, 2006 | 11:45 AM
chrisj6's Avatar
thanks, I'll get back on the tuning then!
Chris
Old Jan 10, 2006 | 10:43 PM
1slowsilverado's Avatar
Yup, its all good. Like Crash said if it was way lean look for a vaccum leak. But If you think you have an exhaust leak.Try tranny fluid in the main vaccum line it smoke like a **** and will be easy to find.
Old Jan 10, 2006 | 11:05 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Mine are always in the negative and different. -0.8 and -8.5 once I get into the higher rpm 4K+ they both go to 0 and then when i let off the go negative and are off by 6 to 9 points.I've been told leaking injector or exhaust leak or ignition problem. What do you guys think?
Old Jan 11, 2006 | 07:33 PM
Has it allways done this or just started? Who tuned it, Can you post or send a log file?
Old Jan 11, 2006 | 08:12 PM
1SlowHoe's Avatar
It isn't tuned perfect yet and I was told by a tuner that tuning couldn't fix it anyway, it was a mechanical problem. It started this after th 6L install. We broke a exhaust manifold bolt in the block and had to tap it. I don't know if that has anything to do with it but maybe. I am getting LT's and the exhaust redone soon so I'm hoping this will fix the issue. I do have a log from a couple weeks ago. Want me to send it to you or can I post on here? I'll try.
Old Jan 11, 2006 | 08:40 PM
Is it still leaking though? Sounds like that might be the problem. But let me take a look at the log and tune. Timrichardson@cfl.rr.com
GXPJAY
Feb 13, 2022 08:15 AM
05GMC4.8
Aug 7, 2015 09:55 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
banker099
Jul 4, 2015 05:50 PM
