fuel in the oil pan
Old Mar 19, 2012 | 09:27 PM
Chevyboss22's Avatar
Default fuel in the oil pan
ok i have been battling a 4.8 cam/turbo to 6.0 cam/turbo swap with little annoying issues i just figured out my oil pressure issue after taking off 2 oil pumps and replacing the pickup tube anyway now i fired up the truck which is still setup on the 4.8 tune i havent driven it or anything just let it idle so the oil could flow and coat the internals and charge the battery a little bit motor sounds good no weird ticks or noises after i let it idle for a bit i turned the engine off and let it sit checked the oil and i was over like 2 qts which i did purposely when i was trying to figure the oil pressure thing well when i went to let some of oil out it was watery stuck my finger in it to smell the oil and i can smell fuel so question is now what could be wrong or could it just be that the tune is completely flooding the cylinders
Old Mar 19, 2012 | 09:34 PM
Gadgetized's Avatar
Sounds like it is just rich. Are your plugs black? If so, it more than likely needs to be leaned out.
chopperloco
Jul 10, 2016 10:45 PM
Ls3silverado
Jul 31, 2015 04:22 PM
05SilveradoSS
Jul 29, 2015 08:34 PM
jmarkway
Jul 18, 2015 09:23 PM
