A few tuning issues
Old May 10, 2007 | 12:11 PM
Whippled 496's Avatar
Originally Posted by MikeGyver
Why the capitol letters? It makes it sound like it is my fault. I get enough of that at home. Everything is my fault. Anyway, I too like the idea of a bypass problem.
I Just figured you're such an important guy, they should be capitolized...LOL I didnt get a chance to check the bypass yet, no one wanted to ride in the engine bay while Im boosting down the road....
Originally Posted by talac
Here is a long shot. Have you checked the PCV circuit? my 05 8.1 runs a metered orifice in the intake manifold which will allow boost into the crank case.
Mine does not have a PCV valve at all, its all internal....or is that what your talking about? I really think Im just overspinning this blower, or its not large enough for this engine. How do you calculate blower RPMs? Im not sure what the crank size is on this engine, i will have to look it up of crawl under there and see.
Old May 10, 2007 | 03:07 PM
MikeGyver's Avatar
I safety-wired mine shut once to test it. It was BIC (before intercooler), and man, did the IATs zoom! Also, it makes a real cool noise when you let off the gas.
Old May 10, 2007 | 03:23 PM
kbracing96's Avatar
You could do like Dusty did to see if his blow off was working and duck take a video camera under your hood and go drive around
Old May 10, 2007 | 03:55 PM
dewmanshu's Avatar
Moderately Differentiated
ahhhh duct tape GREAT STUFF!!!!
Old May 12, 2007 | 06:06 PM
Wilde Racing's Avatar
How do I change this text
Are you talking about this?
BTW. I vote for a sliping crank pully.....
Old May 12, 2007 | 10:11 PM
Thats pretty cool Dusty. How can i tell if the crank pulley is spinning other than pinning it then trying again? How are the pulleys pinned?
I know if i can get a few more pounds of boost outta this thing, i could be flirting with low 13's.
Old May 14, 2007 | 08:37 PM
XLR8NSS's Avatar
Adkoonerstrator
Take a sharpie and put a mark on the crank bolt and crank pulley. Go for a few blast and see if they are still lined up. That should tell ya if the pulley is spinning.
Old May 14, 2007 | 08:52 PM
dewmanshu's Avatar
perfect, but I gotta say, if it was slipping, you more than likely would have erradic boost readings. Not super stable like you do now. I said more than likely!! I bet I am wrong. ...the sharpie trick cost nothing though. Unless you are The Breeze who wouldn't write on the motor, that's a suuupppeerrr dooooper idea.
Old May 14, 2007 | 08:56 PM
dc_justin's Avatar
Hello Dave
I beg to differ on that one. Once the starting friction has been overcome, it will continue to slip as we see with his log. He peaks early, then loses boost.
Just my .02.
Old May 15, 2007 | 05:41 AM
Whoaaa whoaaa guys take it easy there....no need to go at each others throat like this. I dont want to see anyone say anything that might come back to bite them....... j/k, just messing with you guys.
I will try the sharpie thing for the hell of it to see what happens, i like that idea even if its not a crank slipping. With my luck it would be slipping, but lining itself up perfectly with the mark everytime it stops....LOL. How does the pinning kit from maggy work?
