A/F ratio
Old Jul 20, 2005 | 09:52 PM
v8
17,16,15,14,13,12,11 Drvr
Default A/F ratio
what is the safest level for a N/A 5.3 to run can i run it at 13.1 or is that to lean? thanks for the help.
Old Jul 20, 2005 | 10:19 PM
Kano's Avatar
I have no hard evidence here but
maybe this will help
I ran a 8.9 in the 1/8th with a
13.0 to 13.4afr tune 28* timing
checked on wideband
this showed as 840-850 on my narrowbands
played with it at the track and fattened it up some
to where the n-bands showed 880-890 and knocked it down to 8.7 same day
I dont know how that correlates to afr and the whole tq vs hp thing and may not be helpful but Im beginning to believe my truck favors a little more fuel
Old Jul 20, 2005 | 10:25 PM
v8
well im running 34 derees of timing and a/f now is at 12.8 untill i get to 6k to 6800 then it goes to 11.7 i might just need to take some fuel away on the topend, im pulling 8.60 in the 1/8th in 90+ weather. thanks for the help.
Old Jul 20, 2005 | 11:12 PM
Kano's Avatar
I read somewhere about running fat down low for tq
lean in the middle and then fatten it back up right at peak and after for a safety buffer
are you running stock heads?
do you see any knock with the 34*?
Ive noticed mine doesnt but doesnt show much gain either with extra timing
when I get mine back on the dyno Im gonna shoot for 12.5 up to 4000
12.8-13.0 4000-5500
and 12.5 beyond that
then Im gonna play with the timing until I find optimum
hope it works
Old Jul 21, 2005 | 05:52 AM
one03sierra's Avatar
Formerly one92rs
Talking
leave it alone. from 12.8 to 13.4 is a good a/f ratio. 6800 and it goes rich. heh. that just might be helping out at that rpm.
Old Aug 1, 2005 | 04:26 PM
Excellent advice. I have tuned many import cars that way and will continue to do so. A margin of safety in any daily street driven car is always welcome
Old Aug 1, 2005 | 07:03 PM
Crash Dummy's Avatar
Former Moderator :(
You may want to turn COT Cat over temp off or adjust it, that is what is most likely your 12.8 to 11.7 problem
Old Aug 1, 2005 | 09:46 PM
v8
yep thats what allen nelson said but i will leave it like it is, no reason to burn up cats at there price lol. thanks for the replys.
Old Aug 1, 2005 | 09:58 PM
02sierraz71_5.3's Avatar
unless you have a wideband stoich afr is commanded unless you enter pe. I would pull timing and try and get your fueling around what gamedawg is saying. There is a point where you can keep adding timing and wont see any gains I tend to think its around 28 degrees with the 5.3 wot, the rest is fueling. Less timing and leaner will make more power and net better times in this instance.
Gamedawg: Great sig tyron is my favorite shapel character shaazamm
Old Aug 1, 2005 | 10:12 PM
Kano's Avatar
mine too
I got to get the crackhead shuffle down
Im gonna "break it down" in mustang alley next time at the track
shazzamm
