Evap Purge Solenoid (Will I miss it ? )
Old Jul 27, 2017 | 02:36 PM
Fullpower's Avatar
Default Evap Purge Solenoid (Will I miss it ? )
Of what possible use is the " Purging "of EVAP system ?
Does the PCM use this solenoid to make a periodic test of fuel system vacuum integrity, using manifold sourced vacuum ?
If it fell off, would I miss it ?
Old Jul 27, 2017 | 04:08 PM
smokeshow's Avatar
Mod with training wheels
It is used to 'purge' the fuel tank of vaporized fuel to meet HC emissions requirements. It is connected to the manifold so the engine can burn the vapor.
Old Jul 27, 2017 | 05:33 PM
TXsilverado's Avatar
I removed it all from my old truck when I went to a fuel cell. there are a couple of codes to tune out. your garage may stink a little more. didn't bother me.
Old Jul 27, 2017 | 08:31 PM
MikeGyver's Avatar
It is used to purge the charcoal canister.
Old Jul 27, 2017 | 11:47 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Well, that depends. Do you have sentimental attachments to inanimate objects?
Old Jul 28, 2017 | 03:46 AM
smokeshow's Avatar
Which gets saturated by vapor from the fuel tank
Old Jul 28, 2017 | 04:48 PM
Fullpower's Avatar
Is charcoal in the little plastic can, back behind fuel tank, near axle ?
Would that nylon tube be suitable for filling the tank from a smaller auxilliary ( reserve) fuel tank, with it's own submersible fuel pump ?
Old Jul 28, 2017 | 07:41 PM
MikeGyver's Avatar
The charcoal canister is about the size of a football. It is in front of the tank on my truck.
