Evap Purge Solenoid (Will I miss it ? )
Of what possible use is the " Purging "of EVAP system ?
Does the PCM use this solenoid to make a periodic test of fuel system vacuum integrity, using manifold sourced vacuum ?
If it fell off, would I miss it ?
Well, that depends. Do you have sentimental attachments to inanimate objects?
Is charcoal in the little plastic can, back behind fuel tank, near axle ?
Would that nylon tube be suitable for filling the tank from a smaller auxilliary ( reserve) fuel tank, with it's own submersible fuel pump ?
