Evap & o2 monitoring check
Old Aug 26, 2013 | 07:38 AM
HRV-LS1's Avatar
Default Evap & o2 monitoring check
Did a 5.3 swap in my 95 GMc. Its a Calif. emissions swap, all components there. The scanner telling me the o2 & evap monitors are not ready yet. The manual mentions going through a certain process of driving and checking with scanner at the end. How many of these cycles or drive patterns do I need to do?
Old Aug 26, 2013 | 06:53 PM
HRV-LS1's Avatar
anybody know?
Old Sep 6, 2013 | 09:14 PM
HRV-LS1's Avatar
Still have been driving the truck, but it still has the same problem, evap &
o2 sensor monitoring systems haven't showed yes. Anyone know how long I need to drive the truck until they clear? Have driven at least 200 miles on the engine, still no change.
Old Sep 7, 2013 | 10:20 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Engine swaps are tough in CA because they go by the year of the vehicle you did the swap from. I believe you're allowed 1 monitor not ready on 99-up.
Evap monitor only sets under certain conditions including outside temp and the gas tank being between 1/4 of the way and 3/4 of the way full when the engine is cold.
With a scan tool you can force the Evap monitor test to see if it will pass. As far as the 02's they should set fairly quickly.
You need to maintain a constant speed for a few miles. Usually 60 MPH. You can't be on/off with the gas pedal you need to cruise steady to set the monitor.
the_merv
19
Nov 15, 2015 07:39 PM
SILVERADO11
Jan 17, 2010 09:50 PM
dmorgan
Aug 13, 2009 03:37 PM
Lurius
Mar 2, 2007 05:16 AM
Black Nali
Dec 15, 2005 09:32 AM
