Engine wire diagram
Old Nov 24, 2011 | 12:51 AM
Fastest Truck Ever's Avatar
Registered User
Default Engine wire diagram
Does anyone know a reliable place to download or get a copy of a wiring diagram for the engine wire harness on an 04 and 00 5.3 silverado 1500?
Old Nov 24, 2011 | 02:06 AM
nonnieselman's Avatar
I have some somewhere. Let me look thru my photobucket.
Old Nov 24, 2011 | 02:23 AM
Mangled03gmc's Avatar
Baltimore Whore
Why would you need that if your the fastest truck ever ???
Old Nov 24, 2011 | 09:51 AM
Registered User
The fastest truck ever g
Old Nov 24, 2011 | 09:53 AM
Registered User
The fastest truck ever got wraped around a telephone pole that wouldent move out of my way. Now the motor is going into a 2000 short bed single cab
Old Nov 24, 2011 | 02:28 PM
Its not working right on my phone.
When i get to some internet on the laptop ill post up the pictures and you can save them.
What exactly do you need?
I have the pcm pin outs and also the fuse box connector pinouts.
Old Nov 24, 2011 | 10:44 PM
Registered User
Thank you so much nonnieselman. Both would be awesome if you could. I put an 04 motor with an 04 harness into a 00.
Old Nov 26, 2011 | 10:04 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Found a copy of the manual here
99-02 cable style PCM is listed here.
Wiring Diagrams - The 1947 - Present Chevrolet & GMC Truck Message Board Network
If you used the 04 harness With the 04 PCM then I will Suspect you will need the Fuse block Pin out as well...
Old Nov 26, 2011 | 10:26 PM
1FastBrick's Avatar
This guy has some wireing info for both the 99-02 and the 03-05 PCM harness
Vortec 4.8/5.3/6.0 Wiring Harness Info
ARC
57
Feb 21, 2022 10:54 AM
thunder550
Oct 8, 2015 04:53 PM
vortecyota
Jul 23, 2015 08:26 PM
bsgiffor
Jul 19, 2015 11:14 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
