Electric fan conversion relay questions us 01' OS .
#41
Coolant temps get up to 200 both fans come on low speed and go off when coolant gets to 198
When the fans are on low speed and the A/C is turned on ... both fans come on high..
Temp is below 200 and A/C is on then just Fan 2 comes on high speed.
If Temp is above 210 at engine shut down the fans stay on low for 5 minutes.
No lights diming and havent had a cooling issue this summer..
Put the same fans on my buddies Z71 and wired it up the same as mine.... No complaints either..
#42
I'm not even running the wire for the a/c at the moment, I have the fans on low 24-7 . . . I moved and I'm spending more time sitting in Houston traffic, and they're still working great
#46
I recently installed twin fans on my 98 Suburban.
They're wired the same as the above drawing.
I have an 0411 PCM and use pins 42 and 33.
Two fans on low at 93oC and off at 91oC
Two fans on high at 104oC and off at 101oC.
I also use EFILive.
If you look at the fans parrameters in an 05-07 truck, it uses A/C auto recirc as 'fan #2 control'.
I also use EFILive.
