electric fan ac tap
Old Oct 21, 2012 | 10:04 AM
loganlewis's Avatar
Default electric fan ac tap
My trucks a 2000 and its got a 2002 os full flashed in with a blackbear tune...I installed ls1 fans and have a harness from ls1fans.com here for it. Everything is pretty self explanitory, but my ac doesnt work and i dont really have an intentions on fixing it. So do i need to tap the ac wire to complete the circuit for the fans to work after they are wired up, or will they still work correctly? If they do have to be tapped, which wire does it even tap because it didnt come with any instructions. The tag just says "ac tap". Thanks
Old Oct 21, 2012 | 10:07 AM
TXSZ66AVLANCHE's Avatar
No point tapping it, ac don't work the the fan control for ac will never turn on. Just install the pcm wire.
Old Oct 21, 2012 | 10:12 AM
loganlewis's Avatar
Ok thanks for the quick response. Guess I know what im doing this afternoon!
Old Oct 21, 2012 | 02:54 PM
loganlewis's Avatar
I go them in, now when I go into DVT in efi, and activate fan 1 and turn on, both fans come on low. When the truck warmed up to temp, both fans turned on low. I thought only one would. Or does that sound right?
Old Oct 21, 2012 | 03:24 PM
Yes, correct for 99-02 trucks.
Old Oct 27, 2012 | 12:26 PM
chris99gmc's Avatar
Keep them wired in series, just like you have it... Having them run independently and kicking on/off on high only has more power surge on the system than both coming on at low and then kicking into high. Chances are you will never even need them both on High at the same time, if you don't plan on using the A/c.
CD82
Oct 23, 2015 07:32 AM
JordanH
Oct 3, 2015 03:59 PM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
