EFI Tuners/Tranny pressure ?
Old Jul 27, 2006 | 04:18 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Ok. I'll change them to 0 and put the stock line pressure back in and see how it feels. Thanks for the info
Old Jul 27, 2006 | 04:44 PM
Mine look like this for D0701:
0.000000 0.000000
0.000000 5.000000
5.000000 8.000000
8.000000 12.000000
12.000000 18.000000
18.000000 23.000000
23.000000 26.000000
26.000000 29.000000
29.000000 32.000000
32.000000 35.000000
35.000000 38.000000
38.000000 41.000000
41.000000 44.000000
44.000000 47.000000
47.000000 50.000000
50.000000 53.000000
53.000000 56.000000
56.000000 59.000000
59.000000 62.000000
62.000000 65.000000
65.000000 68.000000
68.000000 71.000000
71.000000 74.000000
74.000000 77.000000
77.000000 80.000000
80.000000 83.000000
83.000000 86.000000
86.000000 90.000000
90.000000 90.000000
90.000000 90.000000
90.000000 90.000000
90.000000 90.000000
90.000000 90.000000
Nothing compared to you guys. All my shift timings are set to .1. I know that it disables the adaptive learning to set to 0, but my tranny shifts beautifully with the setting that are in there and it has been running this way for 14k miles and at different times, it has had quite a bit of horses turning it. It's very firm under heavy throttle and sort of firm under light throttle. I have the transgo HD-2 kit and a vette servo. I'm reluctant to change anything other than my shift rpms. You don't fix it if it aint broke. These were the settings in there when I was using LS1 edit and Allen Nelson was doing most of my tuning.
If you have the billet servos, give up the fight to reduce that shift punch.
Old Jul 27, 2006 | 05:23 PM
Eye-P's Avatar
Indeed. You may just have to deal with this if you are using billet servos. I would personally not use billet servos again, after going through this same issue.
You could also try a regressive TQM strategy for part throttle/lower torque shifts.
Old Jul 27, 2006 | 06:31 PM
kbracing96's Avatar
Benkey, the # difference in are pressures and yours is, are's are labeled in metric and your are labeled in SAE.
Old Jul 27, 2006 | 06:54 PM
Yep, my bust.
Here:
0 0.000000 0.000000
20 0.000000 34.473795
40 34.473795 55.158073
60 55.158073 82.737109
80 82.737109 124.105664
100 124.105664 158.579459
120 158.579459 179.263736
140 179.263736 199.948013
160 199.948013 220.632291
180 220.632291 241.316568
200 241.316568 262.000845
220 262.000845 282.685122
240 282.685122 303.369400
260 303.369400 324.053677
280 324.053677 344.737954
300 344.737954 365.422231
320 365.422231 386.106509
340 386.106509 406.790786
360 406.790786 427.475063
380 427.475063 448.159341
400 448.159341 468.843618
420 468.843618 489.527895
440 489.527895 510.212172
460 510.212172 530.896450
480 530.896450 551.580727
500 551.580727 572.265004
520 572.265004 592.949281
540 592.949281 620.528318
560 620.528318 620.528318
580 620.528318 620.528318
600 620.528318 620.528318
620 620.528318 620.528318
640 620.528318 620.528318
Compared to slowhoe:
0 0.000000
20 50.633387
40 74.334121
60 91.247827
80 108.161533
100 124.967508
120 141.881214
140 162.134569
160 182.387924
180 202.749009
200 223.002364
220 243.255719
240 263.509074
260 283.762429
280 304.015783
300 330.948436
320 348.185334
340 365.422231
360 382.659129
380 399.896027
400 417.132925
420 434.369822
440 451.606720
460 468.843618
480 486.080515
500 503.317413
520 520.554311
540 537.791209
560 555.028106
580 572.265004
600 589.501902
620 606.738799
640 620.528318
Old Jul 27, 2006 | 07:36 PM
1SlowHoe's Avatar
I drove it around and it feels MUCH better at part throttle. Pretty much stock feeling. I may turn it up just a hair. I just hated the 10mph neck jerk.
Since I have your attention...why does my truck increase rpm by about 300rpm when I shift from D to P and then settle back to normal?
Old Jul 28, 2006 | 10:38 AM
TurboGibbs's Avatar
This is some good info! I have been battling this issue with my brothers' trucks. The low speed 1-2 jerk. I have set the line pressure to 96 in HPT (max) and tweaked some other things. Sorry to hi jack but does anyone have any good HPT files with tq management removed and stock internals?
lukn4trbl355
Oct 21, 2015 11:19 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
carid
Oct 1, 2015 09:22 AM
lxcoupe
Sep 25, 2015 12:36 PM
