EFI Tuners/Tranny pressure ?
Destroyer of Transmissions
These are my current "Base Pressure 1->2 Shift" parameters. I was thinking of lowering the part throttle settings and scaling the whole thing down a little. The 1-2 shift at part throttle is pretty jerky. What do you guys set yours at?
Tranny 4L65E-Built to perform on stock line pressure. (So I'm told)
Table D0701 in EFI Live. Notice how a stock tune doesnt increase pressure until 140 lb/ft of Tq and my tune is already 162.xxx
What do you guys think? Maybe just drop zeros in the first few columns and see if that helps? See post below....stupid excel.
Current settings:
LABELS Transmission Mode
Engine Tq / Normal
0 0.000000
20 50.633387
40 74.334121
60 91.247827
80 108.161533
100 124.967508
120 141.881214
140 162.134569
160 182.387924
180 202.749009
200 223.002364
220 243.255719
240 263.509074
260 283.762429
280 304.015783
300 330.948436
320 348.185334
340 365.422231
360 382.659129
380 399.896027
400 417.132925
420 434.369822
440 451.606720
460 468.843618
480 486.080515
500 503.317413
520 520.554311
540 537.791209
560 555.028106
580 572.265004
600 589.501902
620 606.738799
640 620.528318
Possible Settings:
Engine Tq / Normal
0 0.000000
20 0.000000
40 0.000000
60 0.000000
80 0.000000
100 0.000000
120 0.000000
140 20.684277
160 41.368555
180 75.842350
200 89.631868
220 110.316145
240 131.000423
260 151.684700
280 172.368977
300 193.053254
320 213.737532
340 234.421809
360 258.553466
380 289.579882
400 318.559416
420 341.290575
440 364.021734
460 386.752892
480 406.790786
500 420.580304
520 434.369822
540 448.159341
560 461.948859
580 475.738377
600 489.527895
620 503.317413
640 517.106931
Engine Tq / Normal
0 0.000000
20 50.633387
40 74.334121
60 91.247827
80 108.161533
100 124.967508
120 141.881214
140 162.134569
160 182.387924
180 202.749009
200 223.002364
220 243.255719
240 263.509074
260 283.762429
280 304.015783
300 330.948436
320 348.185334
340 365.422231
360 382.659129
380 399.896027
400 417.132925
420 434.369822
440 451.606720
460 468.843618
480 486.080515
500 503.317413
520 520.554311
540 537.791209
560 555.028106
580 572.265004
600 589.501902
620 606.738799
640 620.528318
Possible Settings:
Engine Tq / Normal
0 0.000000
20 0.000000
40 0.000000
60 0.000000
80 0.000000
100 0.000000
120 0.000000
140 20.684277
160 41.368555
180 75.842350
200 89.631868
220 110.316145
240 131.000423
260 151.684700
280 172.368977
300 193.053254
320 213.737532
340 234.421809
360 258.553466
380 289.579882
400 318.559416
420 341.290575
440 364.021734
460 386.752892
480 406.790786
500 420.580304
520 434.369822
540 448.159341
560 461.948859
580 475.738377
600 489.527895
620 503.317413
640 517.106931
Here is mine, smooth at part throttle, but good and firm, maybe too firm at higher throttle position.
0.000000 0.000000
0.000000 0.000000
0.000000 0.000000
0.000000 0.000000
0.000000 0.000000
6.894759 6.894759
20.684277 20.684277
48.263314 48.263314
64.638366 82.737109
91.571019 117.210904
118.503672 151.684700
140.049794 179.263736
161.595916 206.842773
190.790912 234.421809
213.306609 262.000845
235.714576 289.579882
268.895604 317.158918
303.369400 344.737954
329.871130 358.527472
358.527472 386.106509
379.211750 406.790786
413.685545 427.475063
468.843618 448.159341
517.106931 468.843618
544.685968 489.527895
565.370245 510.212172
592.949281 530.896450
620.528318 551.580727
620.528318 572.265004
620.528318 586.054522
620.528318 599.844040
620.528318 613.633559
620.528318 620.528318
0.000000 0.000000
0.000000 0.000000
0.000000 0.000000
0.000000 0.000000
0.000000 0.000000
6.894759 6.894759
20.684277 20.684277
48.263314 48.263314
64.638366 82.737109
1slowhoe...
Do you have a shift kit? If so, have you zero'd out your desired shift times tables?
If you do have a shift kit, and desired shift times are not zero, I'd suggest starting over with the stock pressures, zero out the desired shift times table (let the shift kit do what it is intended to do), and then go from there.
I was chasing my tail with harsh part throttle shifts like you do now until I zeroed that out.
This tranny is like a FLT but by a non sponsor. It should have a shift kit along with all the other built tranny goodies.
Desired shift times are all .02. for all shifts. Is that high/low? Would changing that to 0.0 make a real difference? Thanks
Your desired shift times table right now is causing the PCM to alter your line pressures to fall in line with the pre-defined targets, which will cause inconsistent and unexpected shift pressure.
With my table zero'd out and having most of my pressures set to stock (high-torque settings have been reduced some), my light throttle shifts are very smooth while heavy throttle gives the firmness the transmission needs.
Originally Posted by dc_justin
Yes, changing it to 0.0 would make a real difference. By setting it to 0, you are effectively disabling adaptive shift learning. What you define as the shift pressure is what you get. And since the shift kit alters the line pressure mechanically, that is what you want.
Yes, defiantly set your shift time to 0, then adjust your shift pressure until it shifts the way you like it. Mine shift nice and soft just like stock at low to part throttle, then at higher throttle and WOT it will chirp the tires.
