Efans quit working! Help!!!!
Old Jun 15, 2012 | 05:41 PM
04Hall's Avatar
Question Efans quit working! Help!!!!
I went through the car wash, and while sitting there waiting my truck began to get hot obviously. So I shut it off, waited, started it up and drove out. Upon my inspection of fans I've found that the relays were semi wet (not saturated) and all the fuses in fuse box by pcm are good which it's not fused into anything. Wired directly to battery ground and jump box. Its the BB harness and I'm getting 13.8 volts to one side of electric clip but not the other? I'm not even sure if both sides are supposed to carry volts but seems like they should? All I know is the damn things won't work! Any more ideas or is the relays shot and I'm in for another harness?
Old Jun 15, 2012 | 05:45 PM
04Hall's Avatar
It was an automatic wash btw and it started to get hot shortly after the undercarriage wash.
Old Jun 15, 2012 | 06:08 PM
2000chevysilverado's Avatar
Sounds like might have water in the relay itself
Old Jun 15, 2012 | 07:19 PM
04Hall's Avatar
How wouldi go about confirming this though? Is it one of those let it dry out things or?
Old Jun 15, 2012 | 07:50 PM
You could let it dry but highly doubt will keep working you should be able to get relays from any auto parts store
Old Jun 15, 2012 | 08:10 PM
04Hall's Avatar
I guess I'll try to re wire in new relays and see what happens, thanks for the info. Still curious to see if its the harness/relays since I'm getting power to one side of the two pin clip and no spinning of the fan?
Old Jun 15, 2012 | 08:26 PM
03sierraslt's Avatar
Shouldn't have to require anything. Unplug the relay and install new one. Double check that your ground is tight.
Old Jun 15, 2012 | 08:38 PM
If you have power to a fan check to see if you have ground on the connector if not then check your ground on the harness make sure its clean and tight if still no ground on the 2 pin lug to the fan then its the relay
Old Jun 15, 2012 | 09:15 PM
dewmanshu's Avatar
Moderately Differentiated
Yeh, the relay cubes plug into a base. They aren't terribly expensive and you should have spares on ya anyway. So buy relay replacements, replace one at a time (plug and play) until you find the culprit.
But like 2000chevysilverado is mentioning, if you actually have power at the fans, that's a different ball of wax. Then you likely have a bad fan. Voltage tester, test those clips. Test across both pins and test both pins separately. But this is a waste of time if you have a bad relay.
Old Jun 15, 2012 | 09:16 PM
04Hall's Avatar
Okay thanks man
