E85 NA...Anyone running this?
Old Jun 29, 2011 | 10:33 PM
  #21
RSTinOKC's Avatar
Originally Posted by cfaluck13
Im curious if i could run e85 on my 4.8 with about 10 lbs of boost with 60's?
Anybody doin this?
Im not sure if i have enough injector fit it
Also remember that more injector will need more pump.
Old Jun 29, 2011 | 11:46 PM
  #22
03LQ9's Avatar
Originally Posted by YenkoST
So, if idle and cruise is 10.7:1 A/F ratio...WOT is roughly 9.1:1?
Also, how's your mpg....down with more fuel being put into the engine but how bad?
Yeah, e85 works pretty good, I've been running it for years with no issues and more power then premium. MPG is lower no doubt but its not too bad. In my 98 reg cab 1500 4wd 350 I get around 13.5-14. With my 03 reg cab 6.0l 2wd 3.42 gears and lean cruise activated I just got 19.2 on a 550 mile trip. Usually on the hwy it gets around 16.5 and if I drive it hard it drops to 13. still cheaper then running premium with cost vs mpg.
Old Jun 30, 2011 | 12:20 AM
  #23
Wheatley's Avatar
Truck Sponsor
Stoich for E85 is 9.87:1 AFR 1.00 Lambda
Ethanol content can vary from load to load sometimes.In the spring ethanol content will start to decrease (depending on your area) from summer.
As winter comes in,you will see more E70 again (depending on your area)
If your truck is not a FFV,an E85 test tube is a good thing to have so you know where to set Stoich.I like mine,it's very useful since my truck is not a FFV.
If your truck is a FFV,then it detects ethanol content.
stealthperf
34
Feb 14, 2016 11:35 AM
Sexyrado327
Aug 2, 2015 04:08 PM
Gadgetized
Jul 18, 2015 02:15 PM
GMCtrk
Jul 17, 2015 06:39 PM
