E85 Conversion Questions
Old Jun 17, 2016 | 09:04 AM
About20ninj45's Avatar
Default E85 Conversion Questions
OK so i searched number threads on here and all the info was either old or not answered. Is it possible to convert a 05 silverado to run e85 on the stock PCM? If so, what would be needed? I have searched through information pertaining to the flex fuel 5.3 tahoes and such(03 models) and have determined that the primary differences were the flex fuel sensor, injectors and fule pump, along with the o3 pcm OS. Other than that, there isnt a other differences is their?
Old Jun 17, 2016 | 09:28 AM
smokeshow's Avatar
Mod with training wheels
What are your goals? Actual flexible fuel capability or just running a fixed ethanol concentration? Things are much simpler if you stick to one type of fuel.
Old Jun 17, 2016 | 09:48 AM
flex fuel capabilities...like the 2003 tahoes have
Old Jun 17, 2016 | 10:50 AM
Vortec350ss's Avatar
Your 05 PCM should have all the capability to do it, yes.
Old Jun 17, 2016 | 11:17 AM
There were 05 L59 Silverados so there is no need to use a 03 calibration. O3s used a return style fuel system and 05s were returnless just like a non FF truck. Just add the FF sensor, wiring, and injectors and flash the PCM with a 05 L59 calibration. You could even put your VIN in the calibration to satisfy the VATS.
Old Jun 17, 2016 | 11:36 AM
Thats why i was asking, the pcm has the os in it for e85, so why did those vehicles never came with it from the factory amazes me. I cant tell if my fuel lines are SS or not though... anyone know if they are?
Old Jun 17, 2016 | 11:37 AM
@2zls1
The l59 was swapped for and lq9
Old Jun 17, 2016 | 11:47 AM
@2zls1
Your posts are confusing. The OS for a 05 LM7 and L59 are the same but the calibrations are different,
Old Jun 17, 2016 | 12:10 PM
smokeshow's Avatar
Because calibrating seamlessly between two different fuels is more difficult than calibrating for one fuel. If every vehicle that could run ethanol did, customer complaints would inevitably be higher. Historically, domestic manufacturers have only sold enough flex fuel capable vehicles to meet requirements to receive EPA emissions credits.
Old Jun 17, 2016 | 12:13 PM
the stock pcm that came with the lq9 has the provisions for flex fuel...(although it never came with flex fuel) which is being swapped in an 05 silverado
the silverado never had flex fuel, but the os from the original pcm had the provisions for it also..
i was wondering about if i just added the sensor, pump and injectors, would that be all i needed and how come ones done it.
sorry for the confusion
