E-Fans not working correctly
Need a little help getting my efans to work correctly.
The problem is that the fans constantly run on Low no matter the engine temp or what I have commanded in the tune (using HPT).
High speed works correctly, and comes on at their commanded temperature.
Everything is wired correctly because I can control the fans using the controls in the scanner. (Low, High, Off).
So, it must be something in the tune. But I don't know what. Everything is set the same as a factory 2005 except for AC Fan Temp, which is lowered to make the fans on whenever AC is on...but right now this makes no difference because the fans are on anyway.
These are the settings I am using. Thanks for any help you can give!
- 2001 Silverado
- 2005 Factory Efans and Harness
- Using Pins 42 and 33
Did you read this write up???
https://www.performancetrucks.net/fo...-chevy-484892/
He used the OEM 05-up harness on a 99-02 truck. Your answer is in there. You don't use pin 33 with the OEM harness on the 99-02 trucks.
HTH
The other trigger wire has to be connected to the AC compressor clutch relay wire. That wire is positive, so by me using an OEM harness, I had to add a relay to that wire to change it to a negative in order to trigger the fan relay pack, which is set up to be triggered by negative signals from the PCM.
Your problem is not unique. Lots of guys, including myself, have this issue with early (99-01) truck os applications. I also replied to your post on HPTuners forum.
https://www.performancetrucks.net/fo...-c-not-465926/
https://www.performancetrucks.net/fo...l-time-476546/
