E-Fans not working correctly
Old Nov 20, 2012 | 12:31 PM
nonnieselman's Avatar
I had this issue when if first did Efans..
i ended up goin with the 12212156 2002 OS and it never did it from then out.
Old Nov 20, 2012 | 01:09 PM
AJII's Avatar
Big Kid...I had actually read some of your posts but never found a resolution. Thanks for posting up!
If I apply a Custom OS in HPT will this fix the problem? Or will I have to use an 02 OS?
Thanks!
AJII's Avatar
Unplugging 42 makes them not work.
Old Nov 20, 2012 | 02:19 PM
ok so that means you do have a tuning issue..
Can you touch that pin to a ground and energize the fans?
Old Nov 20, 2012 | 06:06 PM
AJII's Avatar
I'll try this tomorrow and see what happens!
Old Nov 21, 2012 | 11:29 PM
AJII's Avatar
Worked perfectly when I manually grounded it.
So...I bit the bullet and bought more credits and upgraded the OS and it works perfect now. So yes, you can use the factory 05+ setup with a 99-02 and have everything function correctly.
Old Nov 29, 2012 | 01:34 AM
chris99gmc's Avatar
this is good to know. Thanks
Old Nov 29, 2012 | 09:07 AM
BigKID's Avatar
Curious which OS you upgraded to?
Old Nov 29, 2012 | 10:06 AM
AJII's Avatar
12212156 from a 2002 I found in the HPT Repository.
Old Nov 29, 2012 | 10:30 AM
im using the 12212156 2002 OS and then updated that to the COS3 for EFI Live. its been working for years for me.
working on a 99 with Efans and trying to get them not to run when its cold and not up to temp
