dtc's disable rfactory remote start
Old Dec 2, 2009 | 07:19 AM
Allgonoshow's Avatar
Default dtc's disable rfactory remote start
any way to disable remote start not working when dtc's set
I have hpt
Old Dec 2, 2009 | 07:25 AM
04SilveradoMykk's Avatar
What's the code preventing the remote start? You can turn off drivetrain codes, but not body codes. If that's what's preventing the start
Old Dec 2, 2009 | 07:42 AM
i have to usual header codes turned off.
today is p2270, rear o2 stuck lean,
probably needs an o2 which i will fix
but i would like to disable the no start on dtc as any dtc disables the remote start,
pain in the butt in winter time
Old Dec 2, 2009 | 08:18 AM
Dewey's Avatar
you'll probably have to reprogram the alarm controller box if you want it to ignore trouble codes. i don't think HPT can do that.
Old Dec 2, 2009 | 09:04 AM
Well, in HPT you can turn off any drivetrain code.But I don't think Remote Start MIL disable is an option, just go in turn off the codes your having problems with.
I usually do this when people have third party remote start/alarms, and it also makes it cheaper when you need to get a new ignition key because it doesn't need to be chipped or programmed:
P1626: Theft deterrent fuel enable signal not recieved
P1630: Theft deterrent learn mode active
P1631: Theft deterrent start enable signal not correct
make sure the SES enable boxs are unchecked, and set all the those codes to 3-no error reported
Than under System> Security VATS, set to PWM
But really since your getting downstream O2 codes, just turn them off.
P0136,P0137,P0138,P0140,P0141,P0147,P0156,P0157,P0 158,P0160,P0161,P0167
Set them all to no SES & 3-no error reported
Old Dec 2, 2009 | 09:27 AM
wow, good info
thank you muchly
flatblack83
Jan 3, 2026 07:10 PM
shawn96gmc
May 17, 2016 04:15 PM
treylittlefield
Jan 24, 2016 07:38 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
Ketis
Jul 23, 2015 12:37 PM
