DTC P0601 for 2011 silverado
Reviving this thread because issue is happening more often to where I cant even drive the truck. I tried to change the DTC to not alert and that did not band aid the issue. I called my local tuner and asked about if I got a new ECM if we would need to involve the dealership. He said yes if you get a brand new one but if you can find a used one you simply remove the vats, update vin, and anything else you changed on previous tune. With that being said I found the below vendor that can do all of it on a tested/proven ecm PnP basically. I am skeptical of buying one off ebay with no checks done on it. Anyone have any previous work with them?
https://www.fs1inc.com/2011-chevrole...plug-play.html
Alldata is the web service you can purchase that helps diagnose some codes and has good information. There is another website I can't remember the name that does the same thing and shows other mechanic fixes
Update on this one, I bought a ECM from flashmasters the junkyards didnt have one. The plus side is they had them cheap, tested for functionality, and they have flashed ready for plug and play. Once I got it in and drove to make sure no DTC's came up. I licensed it with HPtuners and put my old tune changes back in like DoD disable.
lowered907
Oct 17, 2013 10:52 PM
