DTC P0601 for 2011 silverado
Old Mar 22, 2022 | 07:25 AM
smokinlmm's Avatar
Have you inspected the ecm connection? The pins are thin and prone to bending and not seating correctly.
Old Mar 22, 2022 | 02:30 PM
The_W's Avatar
I have not, truck is over ten years old and never moved anything there. But that doesnt mean it could have moved over time. Worth a check as well
Old Mar 22, 2022 | 06:41 PM
smokinlmm's Avatar
Engine grounds can cause this issuse also.
Old May 16, 2022 | 02:04 PM
The_W's Avatar
Reviving this thread because issue is happening more often to where I cant even drive the truck. I tried to change the DTC to not alert and that did not band aid the issue. I called my local tuner and asked about if I got a new ECM if we would need to involve the dealership. He said yes if you get a brand new one but if you can find a used one you simply remove the vats, update vin, and anything else you changed on previous tune. With that being said I found the below vendor that can do all of it on a tested/proven ecm PnP basically. I am skeptical of buying one off ebay with no checks done on it. Anyone have any previous work with them?
https://www.fs1inc.com/2011-chevrole...plug-play.html
Old May 16, 2022 | 02:06 PM
shakenfake's Avatar
Shlumpt
5 Year Member
Never heard of them personally
Not to side track but I wonder what the alldata method of diagnosing this code is?
Old May 16, 2022 | 02:57 PM
The_W's Avatar
I have never heard of the alldata method
Old May 16, 2022 | 04:14 PM
shakenfake's Avatar
Shlumpt
5 Year Member
Alldata is the web service you can purchase that helps diagnose some codes and has good information. There is another website I can't remember the name that does the same thing and shows other mechanic fixes
Old Jun 2, 2022 | 02:24 PM
The_W's Avatar
Update on this one, I bought a ECM from flashmasters the junkyards didnt have one. The plus side is they had them cheap, tested for functionality, and they have flashed ready for plug and play. Once I got it in and drove to make sure no DTC's came up. I licensed it with HPtuners and put my old tune changes back in like DoD disable.
RacinRust
Aug 29, 2014 12:53 AM
lowered907
Oct 17, 2013 10:52 PM
moregrip
May 20, 2012 11:17 AM
NC_Silverado11
Mar 19, 2012 07:42 PM
sit n' low
Feb 19, 2011 09:08 PM
