dont be pissed at me..
Old Dec 20, 2007 | 10:17 AM
sickREDsierra's Avatar
Default tuning questions....
i know a lot of you will be offended, but i have a freekin handheld, and i have a few questions. <predator>
my truck has responded to the tuner well....but i have a cam/LT header combo going on very soon....and i chose a 116 LSA, small duration cam to avoid driveability issues/idle issues......
my question is, my predator will let me monitor/adjust AFR and LTFT's.....
i read on their website that the "optimum AFR value" was around 12.5 to 12.8
1.) is this close to what you fellers like to see, or is that different than a wideband readout would show?
2.) i have been logging/adjusting LTFT's first, dialing them in over a few days, then AFR monitor/adjustments via PE enrichment.....which i am fairly sure advances timing.... could i just advance it a few degrees at a time and monitor for KR until i get the timing maxed for my performance? or is that dangerous?
and i know, i know.....get a real tune...blah blah. hopefully my handheld doesnt get me scolded.
thanks guys.
Old Dec 20, 2007 | 10:44 AM
TXsilverado's Avatar
12.5-12.8 seems good to me. some push it a little more but i hear its pointless
Old Dec 20, 2007 | 02:05 PM
bump for more opinions
Old Dec 20, 2007 | 02:31 PM
thunder550's Avatar
High on diesel fumes
N/A motors make best power around 12.7 to 13.0
Old Dec 20, 2007 | 02:54 PM
thats what i was needing to know.
thank you!
i know, or at least i am almost sure, that the predator is reading AFR from my stock narrowband sensors......but i read a write-up comparison between predator readouts vs. wideband and dynotune and it was very close...and its all i have so far. i still thought it would be better than a mail order, as i can actually monitor and adjust fueling/spark. i dunno?
next year, i am gonna go the STS rear mount turbo setup, with IC.... i will surely need real tuning equipment then....but until then, this is as far as i am gonna go.. n/a bolton.
i appreciate the info guys.
Old Dec 20, 2007 | 09:06 PM
Dirty Dave's Avatar
thank you!
Rick at sts can email you a boosted tune that you can install with you're predator. When I bought my sts he sent me a predator with it for 400 dollars extra. I really prefer my efi live sd 2bar tune but it ran fine with his tune.
Old Dec 20, 2007 | 09:53 PM
Rhino79's Avatar
9 Second Club
I tune AFR for 13.0 at WOT. In some of the lower rpms I run it a bit richer, like 12.6-12.7.
Old Jan 11, 2008 | 12:25 PM
i think shortly i am may shitcan this predator? the more i get into this tuning, the more limited this tool is.
it seemed neat when i bought it, i was kinda scared of tuning electronically then.
i am going to get a dyno tune and compare it to my current diablo tune i have done...i have taken it as far as i can with the predator for now.
if the dynotune severely outways the predator tune....its gone!
Old Feb 3, 2008 | 05:09 PM
mdwatts11's Avatar
What was the outcome on the dynotune vs. predator? I am looking into getting a predator. My only worry is that I am still under warranty, and want to keep it that way. Does the predator leave footprints on the PCM?
Old Feb 3, 2008 | 05:43 PM
no, leaves no footprint. it works great, until you start modding! with just CAI and exhaust, it really woke the truck up. but now after cam and whatnot...its having trouble tuning.
i like my warranty too!! dont wanna screw it up.
