Dbw to dbc tuning
Old Nov 21, 2015 | 09:18 AM
1FastBrick's Avatar
Custm2500's Rude Friend
You didn't mention which format you need.
If you can wait, I can flash one and read it out for you later in HPT format.
Old Nov 22, 2015 | 01:00 PM
kent91011's Avatar
Ok got it to work 01 Silverado pedals and cable wire as suggested on certain website used 12576106 pcm using Hptuners under systems tab systems options change the 1 in the etc column under the gmt800 to 0 and write entire Walla it works if u have it wired right
Old Nov 22, 2015 | 01:40 PM
03sierraslt's Avatar
how much wiring needs changed?
Old Nov 22, 2015 | 02:58 PM
BlackGMC's Avatar
Resident Retard
awesome. I think this is the first time i have seen someone actually get it to work
Old Nov 22, 2015 | 04:38 PM
LSX Power Tuning's Avatar
I have tuned a couple DBW to DBC conversion's in trucks. I personally dont see the need for it but thats just my opinion. The last one I tuned a few weeks ago used a GTO pcm and I used a van OS. They used the same harness just added the wires for the tps and iac.
Old Nov 22, 2015 | 04:59 PM
kent91011's Avatar
Add wires for tps and iac
Old Nov 22, 2015 | 05:12 PM
I can't vouch for everyone else's reasoning, but mine is simple. To run a reliable 102mm or larger TB. No one has made a reliable 102 yet for the DBW that doesn't use the **** LS3 motor.
Old Nov 22, 2015 | 05:38 PM
kent91011's Avatar
Reason I swiched to dbc evertime I would leave at the track on spray it would cut throttle sometimes a lil sometimes as much as 30% I had all the dtcs to the tb turned off so it wouldn't go in to rep mode. On motor was fine
Old Nov 22, 2015 | 05:58 PM
Vortec350ss's Avatar
Thats the exact problem we will have with a PD blower as well.
The TPIS should be strong enough but they are very hit and miss with the X link on a gen 3 pcm.
XBlackXCheavyX
Mar 21, 2016 11:33 AM
walledition
Feb 3, 2016 09:54 AM
GreatWhiteBuffalo
Nov 19, 2015 09:01 PM
rpturbo
Nov 18, 2015 08:34 PM
Inmydust08
Nov 17, 2015 11:03 AM
