Crank Relearn Explained (sort of)
Old Jul 12, 2005 | 04:56 PM
  #21
Okie5.3's Avatar
Originally Posted by 04BlackGmc
so what happens if you dont do the crank relearmn?
the ecm won't be able to accurately detect misfires and your engine light will stay on
Old Jul 13, 2005 | 12:42 AM
  #22
GMC_DUDE's Avatar
Also I believe it can prevent the torque converter clutch from locking.
Old Jul 15, 2005 | 01:55 AM
  #23
vanillagorilla's Avatar
It does all sorts of fun things. In some cases, you can't start the truck. Other cases it won't let you rev past certain rpms. Just reving alone is sluggish and painful.
This is common amoungst stroker engines. A grip of info can be had at our sister site www.ls1tech.com
Just type in crank relearn in the search menu.
Old Jul 17, 2005 | 11:48 PM
  #24
CAMMIN03''s Avatar
Banned
PCM relearn
Try to crank car.... leave key in on position for 11 mins(no shorter, but longer is ok)
after 11+ mins. turn the key to the off position... let sit for no less that 30sec..
Repeat this 3 mroe times is should crank on the 4th
Old Jul 18, 2005 | 12:52 AM
  #25
Originally Posted by CAMMIN03'
PCM relearn
Thats just for the security relearn, its not the crank relearn I believe
Old Feb 24, 2013 | 09:08 AM
  #26
Richard91952's Avatar
Registered User
Default crankshaft variation relearn
Originally Posted by GMC_DUDE
In another thread (now closed) someone was asking about crank relearn. In a nutshell it is this: One of the requirements of OBDII is that the PCM must detect and report misfire conditions. So how do you detect misfire? Well, the way GM does it is to monitor the time between the crankshaft sensor pulses and the camshaft sensor pulses. Since there is always some slack in the camshaft drive train, the time spaces will be one value if the cylinders are firing and the piston is delivering power, and another value if there is misfire and the piston is just coasting along. However, as you can imagine, every engine has a different amount of slack, so these timing gaps have to be calibrated, or "learned", into the PCM. The PCM has a routine in its software to do this, and the routine can be triggered by a command from HPTuners or the GM TECH 2.
So what's up with the relearn? Well, certain parts changes, i.e. new cam, new timing chain or gears, etc., can change the amount of slack, and the PCM has to relearn the gap values. The thread in question was discussing a custom PCM tune. Not sure how that would monkey up the works, though. Maybe someone else can explain.
Anyway, hope this quick and dirty explanation helps.
Is there a handheld diagnostic scan tool that will help with this relearn?
Old Feb 25, 2013 | 02:11 PM
  #27
hog's Avatar
hog
All GM relearns, CASE, security, trans and idle. Last page helps you identify your system based on your key.
http://www.bsecorp.com/files/techtips/ST9303l.pdf
peace
Hog
Old Aug 20, 2020 | 10:29 AM
  #28
posneg1970's Avatar
Registered User
Default i know its an old post !
hello i know this is an old post but i was wondering if you can help me out
i put in a new crankshaft position sensor 7,8 months ago on a 2000olds intrigue. i didnt do the relearn , cant find a mechanic that does it, and i dont have a scan tool .
aside from slight poor fuel economy , car starts up and runs normal . idle is a little bit rough but nothing to get excited about. anyhow is it possible that i can still do relearn manually without the scan tool? ? if i follow what you posted? please let me know . or should i even bother doing relearn at all at this point , ?it might screw up the cranksensor eventually anyway without doing relearn . thanks for your help!
RustyD
May 23, 2016 07:04 PM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
Wolftrk99
Oct 2, 2015 08:17 AM
trxmxzx
Sep 29, 2015 07:42 AM
