Converting AWD t-case to RWD only to get it on a dyno to tune??
Old Oct 16, 2008 | 10:18 PM
Default Converting AWD t-case to RWD only to get it on a dyno to tune??
I Know Someone Has Done This On Here Before And Need To Know How To Do It. I Can Pick Up A T-case Cheap And Mod It To Make It Work If It Is Possible. This Is For Tuning Reasons, My Truck Does Not Fit On Any Awd Dynos, Too Long Of A Wheel Base.
Old Oct 16, 2008 | 10:29 PM
marlboroman71818's Avatar
remove front driveshaft?
Old Oct 16, 2008 | 10:39 PM
THIS IS WHAT EVERYONE IS SAYING BUT DOES THE CLUTCH HOLD UP TO THE POWER??
Old Oct 17, 2008 | 10:12 AM
built408's Avatar
remove the front driveshaft, I've seen it done a million times, it holds just fine.
Old Oct 17, 2008 | 10:57 AM
nonnieselman's Avatar
is there a clutch in the transfer case?
Old Oct 17, 2008 | 12:51 PM
Bish's Avatar
Depends on the t-case. The 08's use a Borg Warner that is an open differential type. The NV149 (I think) used on the pre-2007 awd is a clutch activated one.
I have been told NOT to disconnect the front driveshaft on the borg warner unit.
Old Oct 17, 2008 | 02:12 PM
Hawk179's Avatar
I built one. I did one for marks truck with the Twin Turbo setup we did some time back.
I took a spare case and welded the viscous coupler shut, and welded a couple other gears together and took out the drive chain to the front unit, worked like a champ. Help almost 900FT lb of TQ so far.
R
Old Oct 17, 2008 | 05:21 PM
R
no vibrations at high speeds???
Old Oct 18, 2008 | 12:30 AM
Hawk179's Avatar
Nope.
Old Oct 19, 2008 | 12:43 PM
Nope.
YOU WOULD NOT BY ANY CHANCE HAVE PICTURES OF WHAT YOU WELDED??
