converting 99pcm to 2002
Old Nov 26, 2007 | 09:58 AM
Phantom's Avatar
11 Second Club
Default converting 99pcm to 2002
how do i do it? do i have to do a custom os?
Old Nov 26, 2007 | 05:04 PM
Phantom's Avatar
11 Second Club
bump...
Old Nov 26, 2007 | 05:58 PM
kbracing96's Avatar
Are you still trying to use it in a 99, or are you putting the PCM into an 02? You should be able to put what ever stock OS on the PCM that you want with a full rewrite, 99-02 that is.
Old Nov 26, 2007 | 05:59 PM
Rhino79's Avatar
9 Second Club
No COS needed, just swap the pcm. You will need to copy and paste all your calibrations in your 99 pcm over to the 2002 OS (12212156), and you will be set.
Old Nov 26, 2007 | 06:00 PM
Rhino79's Avatar
9 Second Club
Yep 12212156, I use it all the time on 99 and 00 pcms.
Old Nov 26, 2007 | 06:02 PM
Phantom's Avatar
11 Second Club
cool thanks guys...
Old Nov 26, 2007 | 06:12 PM
RandomHero's Avatar
if I can do it it's easy.
Old Nov 28, 2007 | 07:26 PM
454SuperSport's Avatar
huh? i thought you had to have a 12200411 code pcm to use a 2002 file?
Old Feb 1, 2008 | 08:33 AM
TURBHOE's Avatar
i thought there was something to do with altenator wireing. if you didn't do it then you would get a battery light. a guy at work wants to swap his 99 pcm to a 01 to get rid of the false knock problem the 99's have.
Old Feb 1, 2008 | 09:18 AM
shupe's Avatar
The 99 to 02 "upgrade" was easy. Didn't change the alt wire. Just disabled the DIC code for the alt. Don't recall which DIC it is off the top of my head.
You can do it.
