Converter wont stay locked
Old Feb 18, 2009 | 07:13 AM
  #21
nighthawk08's Avatar
Originally Posted by Wilde Racing
Raise the threshold between the apply and release sides of each gear...
Are you sure the converter is releasing due to a misfire?
Do you mean have a larger difference between the apply and release speeds? I have tried up to like 40 apply and 20 release and it still doesn't help. No misfires here.
Old Feb 18, 2009 | 08:55 AM
  #22
Wilde Racing's Avatar
How do I change this text
What is the tps sensor reporting right at the problem area...
Do you have a log?
Old Feb 18, 2009 | 08:59 AM
  #23
Do you have a log?
i do but I didn't check to see what parameters I'm currently logging lol. I was going to try to get some better logs tonight.
File Type: hpl
Old Feb 18, 2009 | 03:49 PM
  #24
here's a log with most of the trans parameters.
File Type: hpl
Old Feb 18, 2009 | 05:15 PM
  #25
dlt76028's Avatar
hey i just did this earlier and i got it to stay locked on the highway, it just takes about 5 minutes to warm up. then it locks and stays locked so far.
Old Feb 18, 2009 | 05:23 PM
  #26
what were the stock numbers for the highlighted cells?
Old Feb 18, 2009 | 05:28 PM
  #27
dlt76028's Avatar
this is completely stock
Old Feb 18, 2009 | 05:53 PM
  #28
all that seems to do is make my part throttle 1-2 shift really harsh. still unlocking.
Old Feb 18, 2009 | 06:03 PM
  #29
dlt76028's Avatar
might be a little different with hp tuners.. look at post #8
http://www.hptuners.com/forum/showthread.php?t=1790
Old Feb 18, 2009 | 06:26 PM
  #30
Truckshop's Avatar
do you mean that it unlocks when you let COMPLETELY off the pedal? if so i am pretty sure that is normal. you don't notice it with the stock converter cause of the lower stall speed. i do believe that ed wright has a tcm that will solve this concern you are having.
