Converter wont stay locked
Old Feb 18, 2009 | 06:44 PM
  #31
bluecajun5.3's Avatar
11 Second Truck Club
i'm pretty sure the converter should stay locked when you let off the gas (as long as your above the ttc lock mph). when you hit the brakes, then yeah it will unlock.
Old Feb 18, 2009 | 07:11 PM
  #32
Truckshop's Avatar
not on the newer trucks with the separate tcm. my brother-in-law fought this on his tbss. it would take about 10 seconds to lock back up after he let off the accelerator. a custom tuned tcm from ed wright fixed it.
Old Feb 18, 2009 | 07:52 PM
  #33
nighthawk08's Avatar
Originally Posted by Truckshop
do you mean that it unlocks when you let COMPLETELY off the pedal? if so i am pretty sure that is normal. you don't notice it with the stock converter cause of the lower stall speed. i do believe that ed wright has a tcm that will solve this concern you are having.
What can ed wright do that I can't with hptuners?
Old Feb 18, 2009 | 08:01 PM
  #34
Truckshop's Avatar
i don't know cause we have hptuners also. never could figure it out but his tcm locked and stayed locked.
Old Feb 18, 2009 | 08:08 PM
  #35
Pcm4less has this too appearantly. The thing is you can't tune the tcm if you do the upgrade.
Old Feb 18, 2009 | 08:17 PM
  #36
Truckshop's Avatar
same company i think. if not then this is who i was talking about.
Old Feb 18, 2009 | 08:33 PM
  #37
Wilde Racing's Avatar
How do I change this text
here's a log with most of the trans parameters.
You need to remove some of those other pids.... I dont see it unlocking???
Old Feb 18, 2009 | 08:39 PM
  #38
ah ok. got you on the newer trucks
Old Feb 18, 2009 | 09:43 PM
  #39
dlt76028's Avatar
nevermind what i said, mines still fucxxx up. if the converter clutch was bad would it still lock up? i can get mine to lock up if i give it 40-50% throttle but as soon as i let off some it unlocks. also i wonder if going vacuum modulated would help?
Old Feb 19, 2009 | 06:46 AM
  #40
Truckshop's Avatar
correction. it is alvin at pcm4less, not ed wright
