Connecting fuel pressure sensor to Hptuners
Old Nov 22, 2008 | 09:08 AM
phasemaster1's Avatar
Default Connecting fuel pressure sensor to Hptuners
Its an electric autometer fuel pressure gauge, do I only need the sensor signal(+). Or do I need the sensor(+) and ground?
Old Nov 22, 2008 | 10:23 AM
03sierraslt's Avatar
I Believe you need both. I think anyway.
Old Nov 22, 2008 | 08:08 PM
Thanks Pat
Old Nov 22, 2008 | 08:10 PM
Wilde Racing's Avatar
How do I change this text
yep... be sure to use the same ground as the gauge so you have no offset
KySilverado's Avatar
Sensor output only here and works fine.
Old Nov 22, 2008 | 08:54 PM
Didnt get a chance to mess with it today. Did you have any difference from your log and gauge display Roger?
Old Nov 22, 2008 | 09:47 PM
Nope. It is erratic sometimes.... I might try bringing in the ground to see if it helps that. Grounding it can't hurt.
Old Nov 23, 2008 | 12:08 AM
Now do you use the ground from the MPVI EIO plug? Or the FP gauge ground?
Old Nov 23, 2008 | 05:38 PM
No go, I need the connector clip for the back of the gauge. Its missing the pins.
Old Nov 23, 2008 | 07:12 PM
I soldered a small wire and stuck it into the gauge at the correct pin and taped it. Might also be the reason its erratic cometimes
